- 31 Oct 2005
- Wirral
The S20 FE 5G does look quite good specs wise, but that's still £700Maybe it's time to look at the S20 fe
Correct me if I'm wrong and hopefully I'm not shot down too much but when it comes to the UK has anyone considered some along the lines of the the Huawei P30 Pro amazing specs and the phone I believe can be bought for around ~£500 its the last of the Huawei line-up to still be supported. I currently have a mate 10 pro & I cant really fault it I do notice its slowed a bit & the battery isn't as good but aren't all phones like that after 2-3 years.The S20 FE 5G does look quite good specs wise, but that's still £700
I think I'll switch my focus to the OnePlus 8T.![]()
Agreed on the slow updates side but I definitely have to disagree about the UI I much prefer it infact I'd say I'm quite against the Samsung UI I've had Samsung before and out of all the brands I've had I least preferred the Samsung. If I were to go Samsung and specifically the Note 10+ I'd defo be going custom UI of some sort. Tbh though most phones don't exactly have the fastest updates especially when it comes to older models... like older Samsung brands probably wont get updates as fast compared to buying a new Samsung each yearHorrendous UI and slow updates
Really? My experience with the 7T has been nothing but positive. It's a cracking phone for the price.
For me, I've been a long time Android user & I've never had an apple device but I'm really tempted to switch just for one generation & to see what its all about. I understand everyone has their opinions on each side but I guess until you try one out you wont know if it works for ya!
As mentioned in my original message I've never made the switch. I just feel like I'd maybe like the apple ecosystem once I try it out. I mean nowadays ofc with Android you can "do more" but I mean I'm pretty sure everything I currently do with my Huawei I'd be able to do with an iPhone. I'd probably stay Android if Huawei weren't getting **** on by google, Us & the rest of the world.I switched from Apple to Android roughly when the Samsung S3/S4 was out. I found I could do more with the Android back then.
I just don't like Apple hardware, 'though.
Apple hardware is absolutely top notch. Ignore the paper specs, the hardware is built to the most exacting standards.
It all comes down to Android or iOS
Samsung is off the cards for me. Can't stand their overlays and bloat.
Not really spent a lot of time with others but wasn't too keen on Oppo.
I'll likely go for the Pixel 5 but not at the rumoured price.
I've just ordered a galaxy s20. What bloat are you talking about, as my tab s6 has hardly any. I'm hoping the phone will be the same.
