Help me choose between these
7 Mar 2005
Northumberland
At present, I have an LG ultrawide with a GTX980.
https://www.overclockers.co.uk/lg-3...escreen-super-wide-led-monitor-mo-107-lg.html
Im upgrading my whole PC at some point but in the short term getting a 3080. I want a monitor that will give me the wow factor in games such as COD Warzone etc over my current LG. My shortlist is:
1 MO-00R-MS MSI OPTIX MAG272CQR 27" 2560x1440 VA FreeSync 165Hz 1ms Curved LED Backlit Gaming Monitor £399.95 £399.95
1 MO-005-GI Gigabyte AORUS FI27QP 27" 2560x1440 IPS 165Hz 1ms FreeSync/G-Sync Compatible LED Backlit Gaming Moni £559.99 £559.99
1 BG-23E-SA **B Grade** Samsung Odyssey LC27G75TQSUXEN 27" 2560x1440 VA 240Hz 1ms Freesync/G-Sync Compatible Cur £499.90 £499.90
1 MO-242-SA Samsung Odyssey LC27G75TQSUXEN 27" 2560x1440 VA 240Hz 1ms Freesync/G-Sync Compatible Curved Gaming M £549.95 £549.95
1 MO-0A9-AS ASUS TUF Gaming VG27AQ 27" 2560x1440 IPS 165Hz 1ms FreeSync/G-Sync Compatible Gaming Monitor £449.95 £449.95
1 MO-155-LG LG 27GL850-B 27" 2560x1440 NANO IPS 144Hz 1ms FreeSync/G-Sync Compatible Widescreen LED Gaming Monit £439.99 £439.99
Advice appreciated
Do you have normal room lightning, or do you prefer darkened room?
Untill we get proper FALD backlights IPS just isn't good for darker room.
Again while VA's way higher contrast shines in giving good looking image in dark environment, as rule they have "challenges" in dark colour transition response times.
I play in a well-lit room with a large window to my right.
Advice appreciated
Some cracking monitors on your list, heres another one
https://www.box.co.uk/ASUS-PG278QE-...HXIAh3GsYNPYTVJc-iF9WD2Gwdv7GfuRoCaC4QAvD_BwE
So weakest area of IPS certainly doesn't show, while you might pick up VA's horizontal gamma shift.
To really be upgrade would be just better to get 32" instead of 27".
Unfortunately for some inexcusable reason it's like panel makers lost knowledge how to make anything between 27" and big 50" TVs and there are very few high refresh rate monitors in 32" size.
Acer Predator XB323UGP might be only available model with quite recently released AU Optronics panel.
First of all forum rules forbid naming/linking to OcUK's competitors, so you should remove that link.
Second there's no sense in getting Nvidia's proprietary synced to butt monitor for ball and chain marriage into being their slave in future graphics card choise.
Besides AMD's return also Intel is readying to become third player in discrete GPUs.
And third that's Twisted Nematics panel with plain horrible double overpricing.
Apologies. Your three salient points are duly noted.
