- 8 Jun 2006
- leicester
Nice one.enjoy.
Just landed.
I tried DDU, but nothing. Also uninstalling anything that might be controlling the fans. I've emailed Palit support about it - will let you know if I hear back.
Yes it seems so, how well it works we won't know till we try it. I'll keep an eye out on the bios update and test it when its released.Ah, so seems like the firmware update will make it come on less frequently? Good to know!
People who have started receiving their Founders Editions did you all manage to bag on eon release day and they are just coming now, or did you just get lucky and pick one up from the site when the "in stock" label showed?
Old vs new. Just received this morning, also.
Delivered this morning.
Not yet, I’m waiting for the EVGA cable to appear.For the FE owners, has anyone been able to source a 12pin power connector for their PSU instead of using the adapter?
Thanks.@SeeNoWeevil can't find my tape measure, but I'd be fairly confident it'll fit in 7mm gap. It's quite thin and 4mm looks about right.
Still can't get my Zotac to crash.
It's running quite happy with 50/500 oc and boosts to 2055.
Tomorrow is last day under CCR for a no quibble refund and still have a day one TUF OC ordered at a place near me.
Do I believe the internet hype and ditch this card?
Have played about 18h of Assassins Creed Odyssey, few hours of FH4 and countless benchmarks and the thing just won't die. Anything else I try to make this fall over to sway my decision?
I hovered over the EVGA cable but then came to my senses; $40 is a joke. Also, in my case it is a pain to swap the modular cables so sticking with standard cables seems a better idea until the day all cards use the new connector.For the FE owners, has anyone been able to source a 12pin power connector for their PSU instead of using the adapter?
This is the reply i got from Palit CS:
I believe the Card going over 60W is whats causing the annoyance... dunno why they didnt just have the 150W to begin with?
