ggodin
Virtual Desktop Developer
2 points
12 hours ago
You won’t get good performance from a hotspot in Windows. It’s best to use a 5ghz AC or AX router connected via Ethernet to your computer
ggodin
6 points
17 hours ago
No, I’ve said it many times, hotspots don’t perform as well as a dedicated router. I do not recommending using a hotspot
https://www.reddit.com/r/OculusQues...le_to_stream_pcvr_games_at/g70t19a/?context=3
***This reply above is in direct response to someone talking about buying  PCIe card.****
level 2
ggodin
6 points
18 hours ago
Best setup is with a dedicated router with computer wired to it. Hotspots generally don’t perform well
ggodin
4 points
2 days ago
Hotspots tend to perform poorly compared to having a dedicated router so using a dedicated router with your computer wired to it with Gigabit Ethernet is the way to go
ggodin
1 point
2 days ago
Some dedicated PCI-E cards might perform well however, might be worth a shot, it’s just in general they tend to not work well with sustained data transfers.
Etc
etcetc
etc
I got all these just from checking his comments on Reddit 10% of them seem to be him repeating that dedicated router is better than a hotspot, even when wanting to use a pcie card.
