Apparently every password I have ever used has been leaked or compromised and I need to change them all......
Which begs the question what do you use for generation and safe keeping of passwords? I recently switched to iOS and have used 1Password in the past on android but use it exclusively now and don’t use apples built in solution.
Just note that LastPass should you decide to use it was acquired by LogMeIn, not a company I would personally put faith in for securely storing data and doing the right thing.
I find LastPass free version very stable and works well across all platforms.
They don’t work on Apple ID iOS system password prompt screens which is annoying and means you need to remember that password. App developers also need to make sure their username/password fields are set correctly in the app or it doesn’t prompt any password manager. Most apps are fine but some are not updated for the feature.
The only thing you do have to remember is to open the App if you changed a password on another device to get it to sync across. I think that’s an iOS thing rather than a last pass thing.
You also have to select the password as auto full doesn’t normally work with the app if the password is saved as www.website.com
It’s scary how quickly you can spend lots of money through the likes of PayPal when using a password manager. You can get through a check out process in about 15 seconds.
I have just tested it and it's working fine on ios 14. I had to change a setting to allow lastpass to pass over the password though in passwords setting on iphone.
What I meant was that it doesn’t work on iOS system prompts (grey pop up boxes) where you need to enter your Apple ID password.
I wouldn’t put too much stock in throw away comments like that which don’t contain any evidence. The risk is present with any password manager, I pretty much run on the basis that if it’s online, it’s possible that it can be hacked. That’s why things like 2FA exist to mitigate (but not remove) those threats.
I do understand how it works.It hasn’t happened yet and they’ve had LastPass for a while now.Problem with lastpass is when logmein decide to charge for it and they will you just know the price is going to be extortionate. 1password £35 a year small price to pay
