Would be handy if this was added to the OP.
I was going to suggest the same.
Has anyone got a stable oc on their 3600?
Just ran CTR on my 'bronze' 3600. CCX0 had a 4150mhz on all cores and CCX1 had a 4175mhz on all cores but running at 1.25v instead of 1.38v so I had only an extra 200 points in Cinebench but at 10 degree's less. Quite happy with that considering it costs nothing except some setup time.
I havent read anything on the guide about putting CB20 in a folder, dont you just need to install it?
Does anyone know if the 6000+ reference clock issue is resolved in the new version?
It's not - on downloading beta 2 that was the first time I saw it.
For the moment I'm actually using clocktuner as a simple means of manually editing each core - that seems to be working very well as I up it in 25mhz chunks.
It was in the guide from the outset, you have to extract it to the cb20 folder within the ctr files.
This is for the CPU, not the memory.Does this replace the DRAM calculator?
What's your CB20 score?
My 3600 is low as well in terms of Mhz. I am using stock cooler which isn't helping. Going to try the updated version.
I'm regretting my choice a little instead of getting the X lol. I know in the next round I'll be getting something a little better assuming prices are not astronomical.
EDIT: finally put CB20 in the folder... it keeps not completing CB20, as it overheats (80C) lol.
Thank you, I still haven't used the DRAM calculator yet. Hhhhmm which to start with.....This is for the CPU, not the memory.
