225/45/17
Before I collected my car it had a pair of Pirelli P7's put on the front and now the rears need doing so the OCD in me wants to have 4 corners matching.
But after 8 weeks I'm not particularly impressed with them so I'm tempted to stick a pair of Goodyear Eagle F1 - ASY 5 on the front and move Pirelli's to the rear or would there not be much in it?
Will be able to get the Pirelli at "Cost" which is £50 each and the dealer footing the bill for one of them.
Most Pirellis perform like middle-of-the-road tyres and carry a premium price tag. The special ones tailored for high performance cars are the exception based on what I've read.
I had the Pirelli PZero Nero on one of my cars and they were straight garbáge. Replaced them with the Michelin Pilot Sport 3 and I was no longer understeering all over the place.
I'm not sure how the Cinturato P7 compares to the PZero Nero but reviews suggest "broadly similar" so I'd suggest the Goodyears will be much better.
Someone will be along shortly to tell you that if you go that route, you should put the new tyres on the rear. But since the Pirellis are almost new anyway from what you've said, I'd probably do the same as you and have the grippier tyres on the front.
Do you have to get the P7 for the dealer to pay for one of them? If so I'd probably do that, can't argue with £25 a corner really... Unless you are concerned you will be finding their limitations all the time based on your expeirence. If you can get them to fit the Asy 5's for a negligible amount more, I would definitely do that instead.
Just did 6 hours driving in the horrendous rain mainly (until I cleared it then bright sunshine at the coast earlier this afternoon!!) these tyres have supreme grip, cornering even in heavy rain is fantastic and in the dry they give you so much grip, positive feedback & confidence
