What resolution?
It won't be the PSU, COD is a mess since season 6 started, game is running at great FPS for me but random drops like OP and it feels like a stutter mess even though frames are high.
It ran OK on my 2080 super
1440
Razar mouse mat rgb
Razar mouse
Razar keyboard huntsman
Razar kylo webcam
6tb external hard drive
Elgato
2x 27 inch montiors
Cosair case 3 fans rgb
2 internal cosair fans
Also noticed temps on the gpu were at 72 degrees.
I'm going to run the G-force experience today.
What do you class as okay though? I've done loads of digging and quite a few complaining about poor performance since season 6, it's pretty much the norm that performance drops when they launch a
PSUs are cheap...... also probably good to have an 850 plus for the OC aib 3090s. The real power hungry ones and not like the power constrained zotac 3090
Yes but it a takes a little bit of configuration if you’ve never used it before. Or do you have GeForce Experience installed? If you go into settings > ‘enable experimental features’ you can display a performance overlay with alt+r in game which shows GPU usage.
You’ll find that GPU usage in Warzone drops to 70-80% in some areas of the map, meaning that your CPU is now the bottleneck and I think that might be why you’re seeing the drops in framerate.
to test the psu theory is easy peasy, drop the power limit and try again. Try at 80% for giggles.
What PSU is it? A good quality one might be OK. But if its a bit long in the tooth or not the best unit then its definitely a possibility as others have said.
i played Warzone for an hour or so earlier to test it.
My spec:
10900k
32GB ram
Eagle OC 3090
1440p @ 165hz
850w Corsair 80+gold
No stutters or anything and that was everything maxed and RTX on - maintained FPS generally 180+.
I'm using a 3900X though so intel chips will give better fps usually a good 15-20 depending on the game.
