- 7 Jul 2008
- Newcastle upon Tyne
Can some explain to me, in plain english, what DLSS is and the advantage of it
Never used it on multi monitors, I have 2 but I only use one when gaming. But it should work just the same. For instance if you play on a 4k monitor the game may render at 1440p for instance and then the ai uses DLSS to produce a 4k image from this and then you get 4k but at almost double the frame rate of native 4k.So if i am using 3 x 1440p monitors its probable not for that
