CPU Frequency?
27 Feb 2004
Kent
Hello, Have been playing for the first time with overclocking (with a newly obtained second hand Athlon 4X 860K).
Using AMD overdrive I have overclocked it to 4.2GHz from its normal 3.7gHz and it runs OK at 4.2. using a demo flight simulator.
When I am running "no Programmes" it ticks over at 1.695GHz. Is this normal? what decides the 1695MHz frequency? thanks
Mel
A quick Google shows that the minimum multiplier for that CPU is 17.
17 x 100MHz FSB = 1700MHz which within margin of error is what you're seeing at idle.
Thanks - Not sure that I would have thought to search for minimum multiplier! Makes sense now. Mel
