- 19 Oct 2002
- Shakespeare’s County
XF is now a 5 series competitor
... Well other than the engines
So 20k a year and working from home? Makes sense.
Something quite similar actually. Work from my office at home and I run three sites which I visit accordingly. Not rocket science is it @Smokey26It does if his office is at home and he travels to client sites?
XF is now a 5 series competitor... Well other than the engines
Small update - I've taken on board a couple of comments and tried to broaden my horizons. I've started to lean towards a BMW 430D. I quite like the look of the 2 door over the 4 door. It seems to tick a lot of boxes with the additional power and still will do a decent MPG. The specs looks really nice as I'd be looking at more than a basic one. Anything I should be aware of? I'm off to test drive one later, not in the spec I'd have but I thought more to get a feel for how it drives?
From what I read, you definitely want adaptive dampers as the ride can be too harsh otherwise. The BMW adaptive LEDs are excellent too if you do a lot of late night driving
The HK system on 3/4 series is significantly improved compared to a 1/2 series and is worth having if you listen to a lot of music.
Make sure you go for the pro nav (widescreen) on a 2015 car or newer, as it allows for retro fitting of Apple CarPlay into the system without any hassle![]()
Excellent advice - thanks!
It’ll still be rapid but perhaps a little more suited to high mileage
Why not go all the way, 435D?
So, in summary, buy a 530d instead...
That I’m not sure about. A 1.0 civic will likely be pulling 4K rpm at 80mph. An 8 speed 430d will likely be 3k Max. And getting better mpg too.The thing is with most cars, including diesels the economy totally goes out of the window at speed.
You you actually have to drive 60-70 mph to get an acceptable figure.
So it sort of defeats the object of having one.
Our petrol civic 1.0 will probably match or beat most diesel cars at 80mph.
