- 2 Feb 2010
- Crowmarsh
Another vote for the Asus TUF here, very impressed with mine. Great board, rock stable.
From what is Dad was said he was looking to use it for streaming and gaming at the same time.What will his son be using the PC for?
And what other parts is he looking at?.
Will he be needing wifi?.
Yeah I follow both channels and from between their recommendations and Amazon user reviews this is the board I was considering. I also spoke to users on reddit and it suggests that the newer revisions are better along with the new bios updates they are more stableGo on youtube and watch Hardware Unboxed X570 / B550 motherboard reviews or Gamers Nexus.
Definitely wouldn't buy 3950X now.From what is Dad was said he was looking to use it for streaming and gaming at the same time.
Here is a list of the original components he had suggested:
CPU - AMD Ryzen 9 3950X (700 GBP)
CPU Cooler - NZXT Kraken Z73 - 360mm (240 GBP)
GPU - Nvidia GeForce RTX 3090 - Founder's Edition (1400 GBP)
RAM - Corsair DOMINATOR PLATINUM RGB 32GB (2x16GB) - 4000mHz (450 GBP)
Motherboard - ASUS ROG X570 Crosshair VII Hero Wi-Fi (400 GBP)
Drives - Sabrent Rocket 4.0 2TB M.2 SSD) (360 GBP), Seagate IronWolf 6TB (160 GBP)
PSU - Corsair HX1200i (250 GBP)
Fan - NZXT AER RGB - 120mm (25 GBP)
Case - NZXT H510 Elite - Black (150 GBP)
Paste - Thermal Paste - Thermal Grizzly - Kryonaut (1g) - 5 GBP
Total - 4140 GBP
I said it is a good list but I could make a PC build for less some of the parts he listed was abit overkill. Please note I have not put in the GPU as I suggested waiting until all the graphics cards are out on the market before hitting the buy button. Please see link here on ************ https://uk.************.com/list/JJwxyk
Yeah my exact thoughts hence why I made a revised version of the list that it is more adequate for what they want to doDefinitely wouldn't buy 3950X now.
And really now isn't time for buying anything expensive.
Release of Zen3 architecture is in 8th of next month and similar to Zen+ to Zen2 jump would put 12 core Zen3 close to 3950X in multithreaded loads while naturally beating it in anything with single core dependancy.
If waterpipes are must, Arctic has actually beefy radiators in Freezer II serie and without fashion overprices.
And there's zero need for very expensive board.
Any proper X570 board has overkill VRMs for stock AM4 CPUs.
MSI X570 Tomahawk is more than enough of motherboard.
In fact its VRM is pretty much at lunatically overkill level.
Also MSI's chipset cooler beats the crap out of marketroid designs of Asus boards...
Which have marketing excrements hiding small heatsinks under them, relying on constant airflow from constantly running fan, with everything positioned under graphics card to be bathed in its heat.
While properly designed X570 coolers of Gigabyte and MSI can run mostly passively.
(which also means fan's failure wouln't be certain catastrophe)
Also for gaming and streaming there's zero sense in big luxury price of PCIe v4.
Adata SX8200 Pro could be found for over £100 less.
Same for Silicon Power P34A80.
And off the charts bat crazy oversizing would make that PSU run at obsolete 80+ standard efficiencies when not gaming.
It would barely reach its best efficiency area under gaming load.
Total - 4140 GBP
MSI X570 Tomahawk here, solid as a rock since day one, cracking board!
I've got the Taichi, its not awful but RAM overclocking is hit and miss depending on BIOS, cold boot issues, poor fan placement and that stupid USB C header all put it firmly in the could do better class. Also can't get PBO to work properly even this far after release.
Auros X570 Elite, Asus X570-P and Asus TUF X570, no issues with any of them.
Are both the M.2 slots on the x570 tomahawk compatible with gen 4 nvme SSDs?
