- 18 May 2010
When benching I did indeed only hit 65c on the 3600XT. I have found once gaming that the temp can peak towards 70c, but is kept under control and nice and quiet. I actually never used the Kaze Flex fan and instead replaced it with a Noctua NF-F12 Chromax to match the case fans I had (2x slim at bottom and 2 more nf-f12s at the top).
It has taken me a while to get the fan curves where I want them to keep the case quiet. I can really feel the heat coming out above the motherboard. I will run a Heaven benchmark and get back to you.
That would be appreciated thanks. I reseated the cooler and changed the paste to MX4 but same result of 72c
it's very quiet compared to the Wraith Prism but a 6 heat pipe 120mm tower cooler Vs a 92mm cheap down draft cooler the temps just shouldn't be the same I was expecting more to be honest
