Going from Sandy Bridge you'll see a big jump with a Ryzen 3000. 8 cores would be plenty so grab a 3700X and a decent X570 or B550 motherboard. You have the option then of going to Ryzen 5000 in the future. 3600MHz RAM too.
I thought Asus had the worst support
https://www.google.com/url?sa=t&sou...ARAB&usg=AOvVaw01h6-KgUNlxFtNf8un5Eoq&cf=1
You're still buying twice and buying inferior components for a lot more cost. But it's your money so do with it what you will. You wanted advice, I gave it.
Don't get me wrong, Zen 2 can run hot so don't skimp out on the cooler if you're going to hammer all 8 cores with rendering. But we're not talking ludicrous volcano temps that Intel are currently lumbered with, and certainly nowhere near as hungry.
There are refreshed X570 and B550 boards coming too which are Zen 3 ready. Keep an eye out for them.
How exactly is an Intel CPU inferior for gaming? I just don’t see AMD being that much better for gaming and what price advantage they had is very much reduced with Ryzen 5000.
1080p gaming lol. What is this 2003?The one thing Intel had was 1080P gaming, you were paying more but you did get 10% higher performance at 1080P with a very high end GPU.
Now if AMD have 10% higher performance what do Intel have?
Intel also had/ has a claim on older games that use DX11 and like single core performance.
If AMD does come out on top intel literally have nothing except they might end up being cheaper
So you should be too, that's a great result on the OC - that will see you through a good while I imaginePleased with i9 10850k, got it at 5ghz all core and 1.23v so cool and fast. Not as ground breaking as Sandybridge and Skylake, but it will do for a while.
Around 58c gaming on H100x cooler, fans still on the high side, need to drop them a bit.What temp is it running BTW
Thanks
The quality was poor back then also.Most were on CRT in 2003. Only some were starting to get into TFT then plus they were crazily expensive and if I remember correctly they were 4:3 or 5:4 then.
That temp looks good to me, thanks
I had one of the last CRTs, a 21" Samsung Syncmaster that could spit out 2048x1536.The quality was poor back then also.
I recall a client spending about £800 for a Philips 15" TFT and it looked terrible compared to a £500 CRT.
