Sony XF90
11 Jan 2011
Hi anyone got issues with their XF not connecting to the internet?
Tried connecting via WiFi and LAN and neither work. Super confused.
Usually use a Firestick with no issues but that's being used in another TV so have to use the built in apps on the TV.
Frustrating!
EDIT: Nevermind, fixed it, didn't realise the date and time stopped the internet from working..
18 Feb 2015
Pass. Who knows what they will f up and downgrade like happened with other models in the past. The only thing I'd care is if somehow it would fix the bootlooping issue for 120hz + HDR, but I doubt it.
OP
26 Jun 2009
Uckfield
I have Disney+ on my XF90
My main issue is the TV not being able to find the wifi when it turns on, so I have to manually select it and then it connects without issues.
I don't have that issue. I am plugged in via LAN now anyhow but its a shame its limited to 100Mbps!
Caporegime
21 Jun 2006
are you on latest firmware it addressed wifi issues. also it depends on your wifi settings too i believe. i had to separate 2.4ghz and 5ghz ssids and narrow the 2.4ghz channel
21 Aug 2006
I’ve just found Disney+ on the app but it says “Your device isn’t compatible with this version.” Can someone else try please and see if they get the same message?
7 Dec 2010
Leeds
Works fine on mine have been using it for months now. Make sure you are on a new firmware for your tv, download it from sony and stick it on a usb stick and update.
I'm running v6.6520 but there is newer one now I think.
