The Ampere RTX 3090 Owners Thread
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome all and on TROH.:)
The Roll of Honour.
Date 20/10/2020, Make PNY XLR8, Cosimo, Link
Date 20/10/2020, Make Palit GamingPro, Brok, Link
Date 20/10/2020, Make NVidia FE, Stu999, Link
Date 20/10/2020, Make NVidia FE, scrivz69, Link
Date 20/10/2020, Make NVidia FE, pyxis_00, Link
Date 19/10/2020, Make MSI Gaming X Trio, sd1cko, Link
Date 17/10/2020, Make Zotac Trinity, wickfut, Link
Date 17/10/2020, Make Asus TUF, WhiteHawk77, Link
Date 17/10/2020, Make Palit GamingPro, jimmy321, Link
Date 17/10/2020, Make Asus Strix, DxFlame, Link
Date 16/10/2020, Make Palit GamingPro, Jarrastafari, Link
Date 16/10/2020, Make Zotac Trinity, Jarrastafari, Link
Date 15/10/2020, Make Asus Strix, Drazek, Link
Date 14/10/2020, Make Gigabyte Gaming, darkBytes, Link
Date 13/10/2020, Make MSI Ventus X, cadmunkey, Link
Date 11/10/2020, Make MSI Gaming X Trio, ketma, Link
Date 10/10/2020, Make MSI Gaming X Trio, bemaniac, Link
Date 10/10/2020, Make Gainward Phoenix, Jose, Link
Date 08/10/2020, Make Gigabyte Gaming, Zsooo, Link
Date 08/10/2020, Make Asus TUF, Marc250, Link
Date 06/10/2020, Make MSI Ventus X, kitkat9933, Link
Date 06/10/2020, Make NVidia FE, cHk4, Link
Date 06/10/2020, Make NVidia FE, Quare Crack, Link
Date 05/10/2020, Make Zotac Trinity, m4rmite, Link
Date 05/10/2020, Make NVidia FE, tatts, Link
Date 04/10/2020, Make NVidia FE, Addicted, Link
Date 04/10/2020, Make MSI Gaming X Trio, xb8browney, Link
Date 02/10/2020, Make Palit GamingPro, 0121danwilliams84, Link
Date 01/10/2020, Make Gigabyte Eagle, Sedgey123, Link
Date 30/09/2020, Make NVidia FE, RexAlba, Link
Date 29/09/2020, Make Asus TUF, Bigminimus, Link
Date 29/09/2020, Make NVidia FE, Strife212, Link
Date 29/09/2020, Make Asus TUF, BaueruTc, Link
Date 26/09/2020, Make Gigabyte Gaming, malachi, Link
Date 26/09/2020, Make Gigabyte Gaming, 1nfern0, Link
Date 26/09/2020, Make Palit GamingPro, Jay85, Link
Date 25/09/2020, Make Asus TUF, Cubed, Link
Date 25/09/2020, Make Palit GamingPro, jabski, Link
Date 25/09/2020, Make Asus TUF, MestasDeejay, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 3090
12 Aug 2008
London
What are people thinking as the best card to go under water? Was dithering on the 80 vs 90, but with 3840x1600 * 120Hz HDR... i tihnk i want the 90.
also going for a 5950x so it would be shameful not to. Just deciding what one to order... as i also want to get its matching block ordered too :/
I want an FE really :(
20 Oct 2020
I've got some coil whine with my FE but it seems game dependent. RDR2 sounded like I had an angry mosquito in my case although it got better over time. Crysis 3 virtually no noise, tiny bit when looking at the weapon customisation menu for a long time.
My FE was so loud when fps was hitting like 240+ FPS on some games/menu screens but its got a lot better over the last week or so.
If i really want to shut it up i just turn on V-sync or limit frames to 60/100 but im hopefull its actually going to stop completely going by the reduction recently (or maybe when i watercool it).
Thanks guys, sounds promising.
I did a BIOS update today and after that I feel the coil whine has been decreasing slightly. RDR2 for sure sounds like a angry mosquito lol. How long did you both had your 3090 before you noticed the coil whine decreasing?
28 Sep 2020
Ive had mine for about a month so honestly about 3 weeks but I obviously wasnt gaming all the time... realistically i'd guess at least 20-30 hours of having it buzzing its head off while gaming.
3 Aug 2015
Only had mine a day! RDR2 was bad to start with and especially the snowy scene on a benchmark run however after an hour or so of play it got better. Will have more of a chance to play the rest of the week and come back with results. So far:
Bad coil whine:
RDR2
Minimal coil whine:
Crysis 3
No coil whine:
Ace Combat 7 (was bad when it first loaded at 1080p and 5-600 fps in the menus :D Solved with switch to 4K).
Will update as I continue to try different games.
8 Nov 2009
West Sussex
Hahaha, you and me both.. I believe we are subject to the same delay. An incident on the M25 causing closures early hours of this morning.
I'm near gatwick area. The "universe" really doesn't want us to have these cards :D
I'm guessing tomorrow for delivery now.
Same here! Delivery rescheduled for this morning!
20 Oct 2020
Bad coil whine:
RDR2
Minimal coil whine:
Crysis 3
No coil whine:
Thanks! The games I've tried so far, will update more later:
Bad coil whine:
RDR2 - Even with V-sync activated.
Mafia: Definitive Edition
Average coil whine:
Call of Duty: Warzone
Minimal coil whine or none:
World of Warcraft
24 Sep 2020
Lovely looking build! However you could do with either flipping your rad 180 degrees or top mounting it. All the air will gather at the top of the rad over time as your coolant levels deplete (plus the small amount of air already in there from manufacture) and your CPU temps will slowly creep up while your pump impeller starts to fail too over time due to your hoses sucking more and more air with them being at the top of the rad and above the pump.
16 Nov 2016
New build almost ready for assembly :D
And what is wrong with the img tags on this site??
7PnDKbx
Man of Honour
OP
21 May 2012
Dalek flagship
7PnDKbx
Welcome and on TROH.:)
The Roll of Honour.
Date 21/10/2020, Make NVidia FE, Private Custard, Link
16 Nov 2016
Forget the PC, nice floor standers! I'm looking at the RF-7 III's... Trying to organise shipment from a seller in Germany to Netherlands, they are painfully slow on responses.
Cheers :) RP-260F's. They can take a beating!
Each floorstander is paired with a BK XXLS400 sealed sub, 400w each. The Klipsch floorstanders are very capable, but add 2x400w sealed 12's, and it becomes utterly terrifying!
