- 6 Jan 2013
- Rollergirl
Only for enthusiasts that are happy to try and fix stuff that doesn't work - otherwise stick to nvidia.![]()
FTFY
Im a 1440p 165hz forever kinda guy.... could certainly make use of a 3080 as ive never been even close to 165fps to date lolOn a 4k 120Hz monitor, yes you do.
Although I have to say, if I hadn't bagged my 3080 then I would be trotting along quite happily at 1440 with my 1080ti.
As @Kaapstad said, it's only a GPU. Mine won't even be powered up for the next couple of weeks![]()
It's not a high refresh card, mate. I have a 1440p 165Hz monitor and it can't push the refresh consistently. It looks like a CPU bottleneck but there's an architectural restriction of some kind going on that I don't really understand. As the resolution gets higher, the GPU performance gets better.
It's really a 4k card IMO.
It's the fastest card available (3090 price/performance is not reasonable). That makes it also the best for high-refresh rate games. Doesn't scale as well, but still, it's not like there's anything faster even at 1080p
I actually dont understand given the joke stock level from Nvidia since Pascal launch why anyone thought they would not be waiting months for a card. Its clearly a strategy from Nvidia now to have limited stock at launches.
Also it does not make business sense for OCUK to hold back stock from customers, the longer it draws on, the more people cancel and less money they make.
In that case, there really isnt any card that can push high refreshIt's not a high refresh card, mate. I have a 1440p 165Hz monitor and it can't push the refresh consistently. It looks like a CPU bottleneck but there's an architectural restriction of some kind going on that I don't really understand. As the resolution gets higher, the GPU performance gets better.
still it should produce higher lows...It's not a high refresh card, mate. I have a 1440p 165Hz monitor and it can't push the refresh consistently. It looks like a CPU bottleneck but there's an architectural restriction of some kind going on that I don't really understand. As the resolution gets higher, the GPU performance gets better.
I'm surprised how quickly people seem to have forgotten the last few launches. I quickly learnt to sit back bide my time until the price and availability was right for me for what I need.
Anyone old enough to remember ordering through catalogues and direct mail orders where the then standard of 'allow 28 days for shipping' was the norm?
I think I remember my brother had to wait months for the new Amstrad CPC464 to arrive.
Yes, bought the kit version of the ZX81 and had to build it when it arrived!!
You were lucky, all I had to play with computer wise as a kid was an abacus.
Frame rate isn't a linear measurement of performance - http://www.mvps.org/directx/articles/fps_versus_frame_time.htm
The % impact of features when you enable/disable them are going to seem more or less harsh on your frame rate depending on what your frame rate baseline is. In other words it's easy to add more frames when you're at 60fps to go to say 80fps. But to add more at say 120fps to go to 140fps it's much harder, even though the delta of 20fps is the same. And so people running very high refresh rates are running into diminishing returns. Which as you expressed it another way, as you jump to higher resolutions the punishment seems less harsh because higher resolutions is more work which means lower baseline frame rates which means easier deltas to achieve
I remember not getting the Amiga 1200 for Christmas I asked for, then about a year and half later it arrived, but by then my dad then decided he no longer wanted to give to me, don't know what he did with it.
