Forza Horizon 4 Bench Thread
26 Sep 2017
In the Masonic Temple
OK. I think that this is about my limit unless I stump up the courage to do this bios thing. The floor is yours :D
3900x stock 3.8 - 4.6ghz
2080ti @ 2145mhz / 8350mhz
446.14 driver
699wg2C
I can't beat that, I tip my hat to you
15 May 2020
Yeah, it showed me that I could push my system more than I thought possible, I had 8 cores at 4.6ghz, it was nice.
Are you planning to play forza for a while, I need some in game buddies
I'd be keen to have a go online. Not played online much at all. I'll send you a PM :)
16 Jun 2015
I use evga x1 precision to get higher than +1500 on the memory. It's goes up to 3000 max on there :eek:
I can help you with the bios flashing, no problem, what card do you have? I'll even find which ones you can use if you want.
You can only raise the power limit, the voltage slider doesn't do anything unfortunately.
And yes i have a heatkiller iv block on it and custom water cooled. I had to cool it to 31.c to get these scores :D
no wonder ha 31c!
think my stock card not even had the cooler removed since new is sitting around 65c with fans around 80%
dam my rubbish non Samsung gddr6 chips not wanting to clock that much!!
16 Jun 2015
10900k @ 5300mhz 10core/20threads
3090 2x8pin msi ventus (350watt power limit) with gigabyte master 390watt power limit
no quite to sure on core clocks as they jump around a lot! around 1900/1920 maybe! (+131 set)
mem is 10552 (+800mhz)
456.71 - drivers
new scores.
1080p
GPU 206.5
Min 178.5
https://ibb.co/KVYprQp
1440p
GPU 172.1
Min 147.4
https://ibb.co/m5ZkGHm
over to you Illuminist
27 Nov 2006
Coventry
Seeing as I was benchmarking my new 3080 on Forza anyway, I thought I'd contribute.
10600K @4800Mhz
3080 Inno3D X2 OC (Stock 1725/1188)
456.71 drivers
1920x1080
GPU 170.6
Min 146.0
2560x1440
GPU 138.5
Min 118.1
3440x1440
GPU 122.8
Min 104.2
Enough for second against the 3090 in 1080 and 1440. But pulling a solid lead for ultrawide!
26 Sep 2017
10600K @4800Mhz
456.71 drivers
1920x1080
GPU 170.6
Min 146.0
https://imgur.com/PiCKgJN
2560x1440
GPU 138.5
Min 118.1
https://imgur.com/V2Ju4pz
3440x1440
GPU 122.8
Min 104.2
https://imgur.com/sLdAg7o
You can do better than that mate, it's only 0.5 more than my 2080ti at 1440p :p
27 Nov 2006
Coventry
HAHA I know! How embarrassing ;) That's a good score from you though. Shows how well the 2080ti's can overclock.
I'll perhaps revisit this when I get the card on water and fiddle with clocks.
In the mean time I've just done a 4k run too
10600K @4800Mhz
456.71 drivers
3840x2160
GPU 92.4
Min 77.3
Man of Honour
OP
21 May 2012
Dalek flagship
10600K @4800Mhz
456.71 drivers
1920x1080
GPU 170.6
Min 146.0
2560x1440
GPU 138.5
Min 118.1
3440x1440
GPU 122.8
Min 104.2
10600K @4800Mhz
456.71 drivers
3840x2160
GPU 92.4
Min 77.3
https://imgur.com/gFqdZVf
I can not see any of your images.
3 Aug 2015
Hope my settings were correct:
R5 3600 @ Stock
3090 FE @ Stock
456.71 Driver
3840x2160
GPU 110.8
Min 93.1
9 Mar 2004
My first attempt, I'm quite new to this but I think it looks to be CPU limited at 2560x1440? Also I think the 350w power limit on the Palit will be a limiting factor since it was hitting the power target max during this run. Would trying to squeeze more out of the CPU help here?
3900X @ ~4.6ghz
Palit 3090 Gaming Pro @ 1950/10461 (as shown in the Palit Thundermaster app)
456.71 drivers
2560x1440
GPU 163
Min 140
