- 2 Feb 2010
- Crowmarsh
AMD needs to be cheaper than nvidia to sell in good numbers. Need to have a bit more vram too and then I may be tempted.
Then the only answer is more, or less cigarettes![]()
I think this might be the saddest thing I've ever read.Its actually stressful trying to make the right choices with gfx cards this year, i have a preorder for a none OC 3080 but with gibbo confirming manufacturers are OC prioritizing, it makes me want to try my luck with AMD but fears are, is there stock, if preorder how far down the queue will i be compared to 3080 position, if no stock how fast will it come in, all too much for my tiny brain
i know right, what kind of person gets stressed over trival stuff? He need to go outside for a walkI think this might be the saddest thing I've ever read.
Strange that you would be OK buying a 3900X CPU but think AMD have to be cheaper and offer more features for you to consider their GPUs. It just looks like a massive contradiction in logic to make such arbitrary red lines than AMD are under no obligation to meet.
I have a 6950 sitting here. It's a bigger number than 6800. £300.Right now I would buy anything
Surely that's only the case if you can go and buy the nvidia competitor and use it that day. At the moment you may as well sell at the price Nvidia wish to charge as you current options will be the AMD card now or Nvidia in late 2022 when stores actually have some stock. Only when Nvidia stock is sat on the shelf for next day delivery will AMD need to reduce the price.
Strange that you would be OK buying a 3900X CPU but think AMD have to be cheaper and offer more features for you to consider their GPUs. It just looks like a massive contradiction in logic to make such arbitrary red lines that AMD are under no obligation to meet.
- if they are honest and come out with the above, then yeah you'll get the haters going "oh amd are useless" but at least theyre being honest and setting correct expectations to be honest.I have a 6950 sitting here. It's a bigger number than 6800. £300.
You know I'll be happy if they say "we're making them as fast as we can, but due to the expected demand, it will be difficult to supply these to all, however we'll be supplying them as much as possible"
because lets face it, unless they've got a few hundred thousands locked up in a warehouse somewhere that nobody knows about, there are gonna be stock problems- if they are honest and come out with the above, then yeah you'll get the haters going "oh amd are useless" but at least theyre being honest and setting correct expectations to be honest.
