- 25 Mar 2004
- Fareham
I have an existing extending wall bracket that is built like a sherman tank. It has served me well for two TVs so far.
Looking at the CX now but I am worried that the holes on the TV are not centered and it will create issues with my wall bracket![]()
The holes are lower down, so your TV will be higher on the wall if your current VESA mount is more central.
Some brackets let you adjust the height on them, but if not, you may need to reposition the bracket.
