- 10 Aug 2006
December the 8th...Goodbye Nvidia, hello AMD
Yep, same.
They don't have 16GB of VRAM but they have more VRAM than 8GB lol.
3070 will be a very disposable GPU for 4K gaming IMO.
Yeah you do, when enabled the slides said it was turned onYou don't know that. They kept saying Best API vs Best API.
Ah I see, the "no answer to DLSS" argument is already in full swing. Nice deflection, boys n girls, nice deflection. I guess you didn't hear Scott Herkelman mention "Super Resolution is in the works" then. And I also see the intentional misreading of charts is in play too. Let's ignore the first batch of numbers and only focus on the Rage Mode and Smart Access scores like AMD are lying about something.
The more things change, the more they stay the same.
hahah no... Setting will be reduced for Computational power way before vRam, the new 6x stuff doesn't work like normal 6 ram, AMD bring Infinity cache that does the same job as Nvidia just moving it in and out of memory on the fly at lightspeed/raw power, same job different approach.And due to that VRAM limitation its going to be even lower settings![]()
Yeah Best API.. They showed these exact slides later with smart access on top of it in light color...You don't know that. They kept saying Best API vs Best API.
I'm happy to wait and see.
NVIDIA owners are trying to convince themselves 8GB is enough but even some developers have said its not.
Maybe AMD just put 16GB of VRAM on their cards for fun.
That's because they were highlighting the uplift in that particular slide.
No mention of crossfire
Has anyone experimented a dual RX5700 setup?
I reckon there are 20 games that cam do DX12 mGPU.
Which proves decisively and once and for all that NV cheaped out on 70 and 80 VRAM, in line with their long held tradition of riipping people off with low VRAM. Case closed.
Well, the echo chamber effect is strong. Nothing much will change anyway as much as you’d like to ignore DLSS and RT. Market share will most likely look the same in 2 years anyway.
If it would have been as good in RT as the 3080 and have an answer to DLSS only then it would have made sense to ask for the same price ( or well, 50$ lower, my bad )
either that or be way better in raster (+20%) like the rumors were suggesting.
