Folks what is "Rage Mode" and this "Smart Memory" thing they refer to in the benchies?
Am I reading it correct that basically 6800 is on par with the 3080 and same with 6900 vs 3090? (ish?)
Raster yes, RT no.
joking of course
So what I'm understanding here is when the actual achievable stable clock could be anywhere between 2015 and 2250, we're just gonna assume it's 2250 forever and always?Wrong, it's not limited to 2015Mhz (charts provided in previous reply to you)
You are still wrong
That's not what I communicated with you. That's an example of how you feel internally being projected in your reply to me.
I cannot help you with that.
RAGE MODE - kicks in when Nvidia owners see the results
Smart Memory - satisfied feeling of AMD owners.
joking of course
Raster yes, RT no.
They never mentioned anything about HDMI 2.1 spec port ?
Architected for the Modern Gamer
Modern set-ups require modern solutions. By embracing industry standards like HDMI® 2.1 VRR, and USB C, AMD RDNA 2 enables seamless integration into your life and hardware setup.
Equipped with GDDR6 memory and featuring PCIe® 4.0 support, AMD RDNA 2 architecture is ready for the new generation of games.
Nice showing from AMD it seems, caveats aside, it looks like they are back fighting it out at the top end.
I'm cautiously optimistic for the reviews now to see just where they stack.
Few thoughts...
Rage Mode -
horrible name, horrible feature imo.
It's - to me at least - something that should be part of the cards base spec.
What they've probably done is not add a mode that when 'enabled' gives more performance, but rather adjusted the typical values of the power limit slider and added a mode that when 'disabled' drops the power limit.
This way they can then say they beat nVidia on power when it is 'disabled' but then turn around and say they beat them on performance when 'enabled'.
It's not a perf boost mode - imo - more a power save mode.
So their 300W Vs 320W/350W is probably out the window when this is taken into effect.
Don't like it, not needed/shouldn't be a thing at all, most people will probably just leave it on.
Again, this is all pending proper reviews etc but it just seems to me like an engineers answer to being pushed to get extra bullet points listed to get one over on nVidia and then marketing and promotion getting involved.
Ray Tracing -
lots of unanswered questions over this one.
Hoping the fact that the new consoles are basically custom AMD PCs will help them out here and that the only reason they haven't mentioned it yet is because current RT titles are a Crysis 3(?) nVidia/Tessellation situation.
Not that exactly but a short hand for what I mean.
DLSS / Super Resolution -
Despite a lot of people seeming to miss this, judging by all the 'no answer to DLSS' comments it was mentioned in the presentation.
Thoughts on this are similar to the above RT thoughts.
Waiting for games to show it off, driver support etc.
Hope they can leverage cross development with the consoles.
Prices
Still too pricey for my liking but I guess that is where we are with tech at the moment.
Want to see what they offer in the sub £400/£500 range.
But if they hit the performance claims against the nVidia equivalents then prices look decent.
Smart Access Memory
Part of me doesn't like this, part of me is like finally! Good on them for leveraging and making the most of their Eco system.
If it's just used as a boost for those that have it then great, if it starts to look like that boost is being pushed at the expense of people running mixed h/w then not so much.
I'm also wondering how baked into the new Zen3 CPUs this is? Or once they have shifted a load of them will it magically appear in a f/w update for older CPUs?
Was a bit worrying that they kept saying things like 'latest 500 series motherboards'. Why not just say current 500 series boards?
Is it purely baked into the CPU, do current boards need a f/w update? Can it be rolled back down the stack a bit?
That probably all sounds more negative that it should but I am genuinely happy that they came out fighting and it looks like they have a great showing at the top end again.
Reviews can't come soon enough and I hope that - for those that can afford it - they don't screw up the launch too badly.
Also, if the Zen to Zen3 journey has shown us anything... bring on RDNA 3![]()
i'm thinking ...could be wrong as an increase in power you could hit 2500 ..amd are playing the low wattage game .. we oc don't .. so lets see were this go'sSo what I'm understanding here is when the actual achievable stable clock could be anywhere between 2015 and 2250, we're just gonna assume it's 2250 forever and always?
Of course it's not limited. It's just not to be taken at face value as a metric
As for the latter part, that was directed more at the people replying to you. Trying to make this like some sort of petty console war tier bickering
Smart memory is AMD's technology where CPU/motherboard and GPU work together to give the GPU much faster access to memory, and Rage is an one click auto overclock feature.
Is it just x570 or is b550 working with SAM also?I would say the 3080 is still a superior choice if you can score 1 at close to suggested prices (so the practical thing to do is wait till 6800XT is available to buy)
The smart memory thing increases the size of GPU memory accessible by CPU from 256 MB to the entire onboard capacity (16 GB in this case) and is exclusive to RX6000+Zen3+X5xx motherboard combo.. Herkelman was talking about gains in the 13% range while the other baldy was showing single digit improvements. The technology hasnt been yet adopted by developers so future gains may be higher
PMSL, you are trolling plain and simple. And, your backpedaling reply is proof of it.So what I'm understanding here is when the actual achievable stable clock could be anywhere between 2015 and 2250, we're just gonna assume it's 2250 forever and always?
He has absolutely no experience with a 5700 series card. And as exampled above he knows the card can boost higher. He's simply trolling.Having had a 5700XT reference since launch, I have never seen my card drop below "boost clock" its always running at or around that speed, even under intense game loads.
Whatever helps you sleep at nightPMSL, you are trolling plain and simple. And, your backpedaling reply is proof of it.
