ok, my bad, ill take another look...They didn't. The 6800XT had nothing, the 6800 had Smart Access and the 6900XT had Rage + Smart Access.
who knows maybe it wasn't by intent or maybe it does run,we have to wait until some reviewers get their hands on them to check it out.It could but why would they if Nv never paid for RTX in those titles?
Nice to see AMD not skimping on the VRAM like Nvidia, but the price rises from both companies are not good to see.
AMD obviously seeing what exorbitant prices people are paying for Nvidia GPUs and wanting in on the action.
Gotta say, dont like how all the benchmarks included the Smart Access tech, its falsely represented the situation a bit in my view. You might still be better off getting a RTX 3080 for example, or 3070, if the performance is the same or better to a similarly priced RDNA 2 GPU without upgrading your CPU.
AMD is doing well though ofc, so not meant as a criticism really.
AMD cards are better for mining.
Previously yes, i have a sneaky suspicion these wont be all that, mining is heavily slanted towards memory, these are running gddr6 as opposed to gddr6x in Ampere.
Ontop of that i dont think the cache will have any impact on mining, so RDNA2 cards may well be inferior to Ampere, and then add in power consumption and these could well be not very efficient.
Radeon VII still the king of mining and i dont think that is likely to change
6800 seems sweet spot for 1440p 144hz and looks to be faster than 3070 for same £££ (unless you can get a founders but good luck with that) and x2 the VRAM!
RDNA is already better than Ampere for mining on a hashrate/watt basis. 2 x 5700 XT is better than a 3080 (where both the 3080 and 5700XT are power optimised).
Yes because of Amperes power draw, and take it from me, i know how good RDNA1 is, i have 6 x 5600XT Sapphire pulse bios modded setup hitting 43mhs each![]()
I think we'll see an 8GB 6800 after the dust settles
You forget how much the "insane" 20w difference means to some people![]()
I'm seeing a lot about gaming performance. But what about the rest? How is RDNA2 at rendering, encoding, machine learning etc? Where is AMD on PyTorch, MXNet, TensorFlow? Does Nvidia have advantages beyond gaming?
Exactly my intention!
I would have been mad to stick with the 3090 after that announcement![]()
Doesn't make it right I don't remember the supermarket increasing the price of toilet paper when it was so popular not that long ago.Ye well, it will be a question of stock.
OCUK sticks it up because there is obvious demand and obviously not enough stock.
If there's enough stock then you can't charge an extra 100 because other retailers are shifting stock at the normal price.
