- 9 Dec 2015
Same, oddly when putting the LLC back to auto (was turbo) I did get a complete run despite the error messages about suggesting to increase voltage compensation.
Did you have Enhance accuracy on too? Try with it off.
He mentions this in patch notes,
You on gigabyte I take it?, use High instead of Turbo or Auto, will hit the desired vdroop sweet spot. Auto will be upto 2.9%, Turbo is 0.5%, High is just right in middle of what he suggests 1-2.3%
I too crash when trying to reach higher clocks on 1.1, but all my previous clocks work, I think its due to new rules, stability checker is def worth running after too and will also expose unstable ram so make sure that is not a factor.
