Ah, right. I did it because I have a 3080 and Gysnc was borked, this new fw has fixed the issue.
Starting Resident Evil 3 in about 30mins to test it is fully working![]()
Not at all jelly
Does g sync only work on dp? I ask I've got a gtx 1080, but I'm connected via hdmi but can't see a gsync option.
src:https://www.nvidia.com/en-gb/geforce/news/g-sync-compatible-2019-lg-tv-available-now/GeForce RTX or GeForce GTX 16-Series GPU or laptop
Anyone played at 1440p 120hz or even 1080? My poxy 2060S will only take me so far
Dam I am looking at 3080, but theres a couple of things in my way, availability, cost (I'm not paying more than RRP), and vram size. I do see a difference between 4k and 1080 where I'm sat so I want to be able to run it full whack.
The firmware that fixes the 4K120Hz bugs is on the LG website so you can update via USB.
that's the sound of da policeWoop woop
The firmware just popped up as an update when I turned on my TV this morning.
I swear I am losing the plot. Have flash drive with just firmware on, but when I insert it into TV it just brings up media options (play music, video etc).
USB around the side (rather then back which I cannot get too) next to the three HDMI ports should work fine right? Pretty sure updated last firmware fine via USB on that port![]()
USB1 on the side is the one I have used. Is it FAT32 and the .epk file in a folder LG_DTV?
what is the current fw via the menu?Yup, had a gibberish name: lib32-starfish-dvb-secured-o18-534.gyeryongsan.o18-53403-05.00.03_prodkey_usb_V3_SECURED.epk
But yeah, that into FAT32 USB stick into port on side. keeps coming up with media options (but of course its not media) when plugged in. Did use USB last time for firmware update when it came out with LPCM update so not sure what's going on now. Tried two different USB sticks, odd!
