Hi guys
Anyone had an issue with using a riser cable and 3090, Card works great in all pcie slots on the msi x570 creation but when installed on the
Phanteks 220mm Premium Shielded High Speed PCI-E x16 Riser Cable 90 Degree Adapter
CM-02P-PT
I get a d6 error, tried everything so can only assume its the riser cable? pc case im using is the phanteks 600s
Cheers Derek
CM-02P-PT
Cheers Derek
