Ryzen 5950X low single core scores in Cinebench R15&R20
2 Jul 2007
Cheshire East
yea your multicore absolutely smashes mine as expected but dont know why my single core is better, What do you think off your temps, while gaming mine are up to between 60 and 70 c at times and thats on a custom loop with 2x360 rads seems a bit hight to me.
OP
3 May 2020
Temps are fine, only when using AVX do spike to 85, but in general use gaming 50-65, so that is not the issue. When rendering, boost keeps up even if temps go over 85. The Arctic 280 is a great AIO, I don't bother ramping it up even when benching. temps stay reasonable. The only upgrade will be a custom with a chiller, but good chillers tend to go for over a grand.
Finally got just 2 sticks and it seems all is better, will need to test. Starting to think that Asus last few bios updates are complete crap and not having the option to revert to an older version makes it even crappier. Considering getting a B550 or X570 MSI Unify don't know. A bit stretched with the purchase.
8 Nov 2020
What did you change to get higher scores? My top score was 632 but its gone for some reason.. but now its down to 620-ish
I have a 5950x too, here a picture: https://ibb.co/Xj579DJ
Xj579DJ
OP
3 May 2020
Just checked Win10 is 1909, when checking for an update says version 2004 is on its way :). Spent far too much time in testing, for now I just enjoy and that's it. Overall the culprit seems to be the bios :), will wait to see if better bios comes up in month or so, otherwise will be getting B550 Unify when comes available.
Found a way to manually update to the latest Win10 version if not offered from Windows Update. https://www.microsoft.com/en-us/software-download/windows10
ps. Looking for a good set of 32GB DDR4 to pair with the IF 2000.
8 Nov 2020
What did you change to get higher scores? Im getting low scores too... check my picture https://ibb.co/Xj579DJ , im on a B550 Tomahawk
