- 18 May 2010
Hi,
I was wondering if anyone here shares my pain administering SCCM? It kind of fell onto me a couple of years ago and now I deal with most things SCCM related and we use it for pretty much all deployments including Windows Servicing and application deployment.
I do like working with SCCM, it takes up a lot of my time, its challenging and rewarding when you get things to work but my biggest frustration with it is Windows 10 Feature Pack Deployment and I was wondering if anyone else has ever managed to figure it out. This has been happening for every Windows 10 release and I am not alone, I have exhausted everything on Google and tried every possible suggestion but the issue remains which is as follows.
When deploying a Windows 10 Feature Update such as 1903 to an 1809 Collection of devices for example, about 75% devices will update as expected however 25% of them will show as Compliant but the update hasnt actually installed and the Windows version remains unchanged on the device. This is accompanied by a Success 0x00000 error code.
The same is true for the 1909 to 1903 Enablement Package which is awesome when it works as its so quick to install with little disruption to the user but it has the same issue as described above on some devices.
The only way I've managed to address this is using a Task Sequence which are majorly disruptive to the user compared to Servicing and comes with its own set of problems.
I've been asked to look at Intune as a potential replacement so would be interested to know if anyone has gone that route, from what I'm reading it might work well for replacing Windows 10 Servicing and App deployment which would be nice but Servers will still need SCCM.
Feel free to share your SCCM frustrations if you have any I might be able to help or if you have a suggestion for the above issue that avoids using Task Sequences for Feature Update deployment I would love to hear it.
Cheers
Cheers
