Permabanned
- 23 Apr 2014
- Hertfordshire
And I laughed and I cried through your whole adventure![]()
It was a learning experience.
Sending it back because it was "faulty" probably the best bit.......
Its a super cheap entry into VR right!
Quest 2 - £399
Cable - £25
New router - £50
Prescription lenses - £60
Games/Apps - roughly £100 (so far)
Cat 6 cabling outside house from router to office/PC. - £50
Fit pack - £30
£714 ish so far(Arguably some wont need all that......)
Not including I had the pro mount/battery/bag on order for 90 quid.
It's not perfect but the standard quest mount is ok.Its a super cheap entry into VR right!
Quest 2 - £399
Cable - £25
New router - £50
Fit pack - £30
You don't need a 256gb quest imo my 64gb was £276 from Argos last week.
The current humble bundle for £13 and all the freebies is more than enough to get you going.
I can't help you on your medical disabilities or your poor hone networking ... I use contact lenses in mine and already have good network (which you don't need if you use a decent usb cable)
I realise you were (or hope you were ,) just joking but the quest really IS a cheap but still very good entry into VR
)Cheers for the detailed reply
How good is eleven table tennis
after a good 30mins+ you get so engrossed you have to be careful not to lean on the table to catch the shots lol
My two main VR platforms:
Quest 2 with Elite Battery Strap + case = £518.
PC with 3900x and 1080ti + Valve Index = £3000 approx, AND I'm looking to spend another £700 on a new graphics card.
Quest 2 is amazing value by comparison! (Though of course I forgot to add the cost of selling my soul to Facebook)
Do you have steam VR installed? They should just work. :/Any tips on getting my quest 2 controllers working in steam VR? For eg, creed, I can't walk or anything because it doesn't recognise button presses on quest 2
That said I have got creed but not played it yet.
Thinking of getting one of these as a Christmas present. Only just started looking into VR but but seems this one is the way to go.
I'm not a Facebook user at all. The Mrs has an account so was wondering how much Facebook is integrated into it? Do you have to log in every time using it? Does it show up messages etc?
I couldn't get telekinesis to work eitherI've tried i expect you to die and it uses what i presume are index controllers. Had to find what i guess is a bug to use telekinesis well enough. Is there a way to switch the layout i haven't seen?
I found if you just twitch the stick towards you, it shoots the object further away, and vice versa, bit confusing, and if there's something that requires me to do it quickly, I'm going to struggle, but it works.
Did you guys try opting in to the Beta? I think it's called indexsupport or something like that.
If you right click on the game in your steam library is there an option to start in Oculus VR mode? If not have you tried using "-vrmode oculus" in the launch options?
