Final Fantasy XV bench
TNA
TNA
Caporegime
13 Mar 2008
Greater London
3600 @ 4.4GHz
RTX 3080 FE @ 1870/5000 (That is what I get from GPU-Z, but in the benchmark it was on average 2000-2050 as I recall).
Driver 457.09
TNA
TNA
Caporegime
13 Mar 2008
Greater London
It seems removing the bandwidth bottleneck issue I had helped quite a bit.
3600 @ 4.4GHz
Driver 457.30
TNA
TNA
Caporegime
13 Mar 2008
Greater London
That crap Zotac one, or so people tell me ;) Nearly 8 weeks old and still going strong.
According to gpuz boosts 2000-2050
Heh, crappy Zotac, urh! :p
My FE depends from game to game. Some I have seen as much as 2160, others 1900. Putting the power limit to 115 helps.
What OC did you do for that run? I think I had mine at 160/5000 and power limit 115. Not touched voltages yet, not even sure if you can.
1 May 2013
M28
That's why I quoted what he said about boosting to 2000-2050 ;)
Maybe he can clarify. Not that it is a big deal :p
Boost limit can change from run to run as isn't it just based off power and temp.
To the other thing you asked AFIAK it was 500 on mem to get it to 1250 and then 75 on the core and let boost do it's work.
Won't be on the PC for the next few days to check since playing Spidey MM on thr PS4.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Yeah, I do get slightly different scores when rerunning benches, but don’t have the patience to run long benchmarks more than once couple of times if doing loads like I did recently. Going to install this bench again and have another crack at it however as I am done with other beaches for now :p
Played the original Spidey last year on a PS4P and it looked awesome on an OLED. Since sold my PS4P and waiting a year or two for some exclusives to build up on PS5. Will play MM on that :)
