Has anyone got it? How does it perform? It's only one in stock.
Didn't that theory of capacitors on back already get debunked?
Not about the caps, about the components and vrm quality , watch the video fully where he compares them with specs of vrm etc. Then see if you are okay with it.Didn't that theory of capacitors on back already get debunked?
Hmmm, wonder if zotac will fix the power limit...Not about the caps, about the components and vrm quality , watch the video fully where he compares them with specs of vrm etc. Then see if you are okay with it.
bingo, also single bios so if you brick it with a flash from another card, you will need another working card in the pc to unbrick it.Hmmm, wonder if zotac will fix the power limit...
Was just gonna chuck a waterblock on it and call it a day lol, how is it running at 2.1ghz with 350w biosI have a Zotac, runs very hot, well the backplate does anyway, but I do have poor airflow in my case. Boosts to around 1920-1950ish stock. Overclocked it boosts to about 2100. Very stable , no crashes on anything yet and I've been playing a lot of games @ 8k and running some extreme graphic mods.
Looking at other peoples benchmarks in games like HZD and Tomb Raider and the Zotac gets the same FPS stock +- 1-2 fps.
If you plan to use it at stock settings then it's perfectly fine, just like every other 3090. If you want to overclock it to hell to then probably go elsewhere or bios flash it with a Gigabyte/Palit.
I have no idea. I just ran the auto OC on afterburner.Was just gonna chuck a waterblock on it and call it a day lol, how is it running at 2.1ghz with 350w bios
Look at the average though.
Zotac Trinity is their low end? It has the 5 year warrantyDidn't Zotac admit they gimped the cards in favor of more higher end models they are launching?
Mmmmmm, they void warranty if you put waterblock on?Yeah and Zotac is quite generous with the warranties but you need to register right after you get it iirc otherwise it's 3 years.
Then why did this fool on the phone scream down at me on the phone that it'll be voided, also Zotac cooler looks like easiest to remove.no. Already contacted them about removing the HSF and they said it was fine, they actually mentioned it'd be better if I tried it rather than wait for more stock on an RMA (I mailed them regarding the heat)
Ah so the overclockers guy blatantly lied to me and was rather rude aswell.
