- 23 Dec 2009
- RG8 9
Just had an email from MTB Monster, my Whyte 905 MK3 should be with me in the next couple of weeks, had a deposit on one since June!
My local bike shop are stating that they will currently be staying open unless told otherwise, they said they are taking the view that they were an essential service during the first lockdown so are staying open on that basis. Dont know what others are being told?
Date been moved back (again) for the Whyte 905, now 25th November. Will it ever arrive? Kind of thinking of getting my deposit back, riding my current bike through the winter and seeing what's about in the spring.
Orbea Laufey H-Ltd due to land in Feb and I am also looking at stock for the Nukeproof Scout.
******* typical. Booked today off so I could pick the bike up, phone up too see what time would be best to get there only to be told they have it down as the 17th not the 12th. Apparently the bloke who wrote the form out has atrocious handwriting and his seven looks like a two. Just you watch, with my luck the thing will turn up on the 17th and it'll be the wrong size frame or have 27.5" wheels instead of the 29" I ordered.
Well, swapped the tyres over to the new spares I had and have Stan's Sealant installed. Glad I purchased the Giant Control tank the other day. Made getting the tyres to "pop" on the rims a fairly straight forward affair.
But mother of god at the mess when taking the old tyres off and the Muc Off sealant!
Will leave the tyres for 48 hours before I go out for a ride, as there's a little bit of sealant coming through some areas where the tyre bead meets the rim. Just need to let the sealant do it's job.
Exactly as @Begbie has said...Will leave the tyres for 48 hours before I go out for a ride, as there's a little bit of sealant coming through some areas where the tyre bead meets the rim. Just need to let the sealant do it's job.
If there's sealant coming through the tyre bead/rim join then there is something wrong. This shouldn't be happening if the tyre bead is seated correctly.
Take the tyre off and check the rim and tyre bead where you can see sealent. Is there excess tape around this area? I.e tape that could be affecting correct seating of the tyre bead?
