The Ampere RTX 3090 Owners Thread
9 Mar 2015
Earth
Looks like I'll be getting 3090. Is FE the pick of the bunch or is there a decent alternative? Dont fancy paying an extra 200 quid to the scalers and chance of getting on drop is slim. Card will go under water straight away.
Would not get anything else tbh unless your into benchmarking. My first one had whine but clocked about inline with what others see with aftermarket models. Build quality is superb on the unit and it was very cool and quiet. New replacement does not have whine clocks pretty well and I imagine unless you really want to hit the benchmarks hard with a 500w BIOS some models have which will only be noticeable in benchmarks mostly, you will be fine.
What waterblock you putting it under straight away though? you got one on order? waiting on the EK one as that block looks amazing for the FE models!
29 Aug 2008
London
Got a Timespy Demo graphics score of 18685 out of the box with my 3090 FE. Is that any good? seeing people get 20k+. Overall score was 14325 with a Ryzen 3600.
Very fortunate though it's rock steady with 0 coil whine.
13 Jan 2018
I am also looking at the Ek waterblock - bit worried how tricky the FE is to disassemble? Plus how does the WB cool the ram on the other side of the PCB?
9 Mar 2015
Earth
Ahh, just a side note block out now to order is 3080FE only, Just cautious when you said you will put GPU under block right away as the EK one has not yet been revealed for the 3090FE.
On the ram, not sure if they will do anything fancy with the 3090 block, if I had to venture a guess the fact water is helping to remove away most the heat will mean PCB will be a factor, couple that with the ribbed back if they do use the same 3080FE block which likely increases the surface area should aid in keeping things good.
Yeah does look a pain in the ass to take apart, but imagine just be patient and have good screwdrivers on hand and you should be okay.
13 Sep 2013
Aberdeen
Yeah, benching days are well over. Availability / cost is more important now than being able to run a bin or two higher!
Block i'll order once i've got a card to put it on. It'll be bought purely on aesthetics, days of worrying over a degree or two are well gone!
1080Ti FE was a PITA so i'd assume these are much the same. Not a big deal tbh, just takes a little longer than an AIB to disassemble...
Man of Honour
OP
21 May 2012
Dalek flagship
Arrived this morning:
:D
Welcome and on TROH.:)
The Roll of Honour.
Date 18/11/2020, Make NVidia FE, Cosimo, Link
Date 18/11/2020, Make NVidia FE, Kaapstad, Link
Date 17/11/2020, Make Asus Strix, Greebo, Link
Date 17/11/2020, Make MSI Ventus X, deuse, Link
Date 17/11/2020, Make Asus Strix, redkrptonite, Link
Date 16/11/2020, Make Asus Strix, JayGee, Link
Date 15/11/2020, Make Palit GameRock (2), Purgatory, Link
Date 13/11/2020, Make Asus Strix, beegul, Link
Date 12/11/2020, Make Palit GamingPro, The_One, Link
Date 11/11/2020, Make Asus Strix, Kivafck, Link
Date 11/11/2020, Make Asus Strix, agnes, Link
Date 10/11/2020, Make NVidia FE, labbby, Link
Date 09/11/2020, Make NVidia FE, Widdle, Link
Date 09/11/2020, Make NVidia FE, Rap1D, Link
Date 04/11/2020, Make KFA2 SG, vapor matt, Link
Date 03/11/2020, Make Inno3D iChill X3, KR-1S, Link
Date 01/11/2020, Make Zotac Trinity, peahead, Link
Date 31/10/2020, Make Asus Strix, Jay-G25, Link
Date 31/10/2020, Make Gigabyte Aorus Master, ronski, Link
Date 30/10/2020, Make Asus Strix, OC2000, Link
Date 30/10/2020, Make Asus Strix, Welsh8bit, Link
Date 30/10/2020, Make Asus Strix, HeatSink, Link
Date 29/10/2020, Make NVidia FE, Radox-0, Link
Date 28/10/2020, Make MSI Ventus X, Mucky_Pup, Link
Date 24/10/2020, Make NVidia FE, ronski, Link
Date 22/10/2020, Make EVGA XC3 Ultra, Skwizle, Link
Date 21/10/2020, Make NVidia FE, mastrchee, Link
Date 21/10/2020, Make NVidia FE, MidKnight, Link
Date 21/10/2020, Make NVidia FE, southy1978, Link
Date 21/10/2020, Make NVidia FE, Private Custard, Link
Date 20/10/2020, Make PNY XLR8, Cosimo, Link
Date 20/10/2020, Make Palit GamingPro, Brok, Link
Date 20/10/2020, Make NVidia FE, Stu999, Link
Date 20/10/2020, Make NVidia FE, scrivz69, Link
Date 20/10/2020, Make NVidia FE, pyxis_00, Link
Date 19/10/2020, Make MSI Gaming X Trio, sd1cko, Link
Date 17/10/2020, Make Zotac Trinity, wickfut, Link
Date 17/10/2020, Make Asus TUF, WhiteHawk77, Link
Date 17/10/2020, Make Palit GamingPro, jimmy321, Link
Date 17/10/2020, Make Asus Strix, DxFlame, Link
Date 16/10/2020, Make Palit GamingPro, Jarrastafari, Link
Date 16/10/2020, Make Zotac Trinity, Jarrastafari, Link
Date 15/10/2020, Make Asus Strix, Drazek, Link
Date 14/10/2020, Make Gigabyte Gaming, darkBytes, Link
Date 13/10/2020, Make MSI Ventus X, cadmunkey, Link
Date 11/10/2020, Make MSI Gaming X Trio, ketma, Link
Date 10/10/2020, Make MSI Gaming X Trio, bemaniac, Link
Date 10/10/2020, Make Gainward Phoenix, Jose, Link
Date 08/10/2020, Make Gigabyte Gaming, Zsooo, Link
Date 08/10/2020, Make Asus TUF, Marc250, Link
Date 06/10/2020, Make MSI Ventus X, kitkat9933, Link
Date 06/10/2020, Make NVidia FE, cHk4, Link
Date 06/10/2020, Make NVidia FE, Quare Crack, Link
Date 05/10/2020, Make Zotac Trinity, m4rmite, Link
Date 05/10/2020, Make NVidia FE, tatts, Link
Date 04/10/2020, Make NVidia FE, Addicted, Link
Date 04/10/2020, Make MSI Gaming X Trio, xb8browney, Link
Date 02/10/2020, Make Palit GamingPro, 0121danwilliams84, Link
Date 01/10/2020, Make Gigabyte Eagle, Sedgey123, Link
Date 30/09/2020, Make NVidia FE, RexAlba, Link
Date 29/09/2020, Make Asus TUF, Bigminimus, Link
Date 29/09/2020, Make NVidia FE, Strife212, Link
Date 29/09/2020, Make Asus TUF, BaueruTc, Link
Date 26/09/2020, Make Gigabyte Gaming, malachi, Link
Date 26/09/2020, Make Gigabyte Gaming, 1nfern0, Link
Date 26/09/2020, Make Palit GamingPro, Jay85, Link
Date 25/09/2020, Make Asus TUF, Cubed, Link
Date 25/09/2020, Make Palit GamingPro, jabski, Link
Date 25/09/2020, Make Asus TUF, MestasDeejay, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 3090
28 Oct 2005
Scotland
I did actually manage to snag a 3090 FE a week or so back now and "upgraded" from my 3080 FE :p I've been pretty fortunate on securing cards so I suppose I should be on this Roll of Honour now :)
This is also my highest score at the moment on 3D Mark Time Spy https://www.3dmark.com/spy/15122684
Graphics Score of 21522 :D It clocks well that's for sure.
I need to stick the overclock back on my CPU at some point to hit over 20000 total score without issue.
4 Oct 2018
Quick heads up ... just bought a GFX 3090 FE online via another site ( NVIDIA ). Still some in stock if others looking.
Dude youre a life saver! Was just randomly checking thge forum for "news" when I saw your post! I was like..nah...no way...then checked anyway! Got a founders as it was still in stock?!! Effme..checked out with shaking hands amd cancelled my tuf oc
Thanks mate!
-btw...if, on nvidia's website the button says "add to cart" and not greyed out saying "out of stock" it definitely means its in stock at the bolton place ((as nvidia iss selling fe-s. through them in the uk) right?
Hope that makes sense..
18 Feb 2007
Thanks mate!
Enjoy your card !
Yup, my card is being dispatched from the Bolton place ... the NVIDIA site linked my order to them.
