- 7 Apr 2017
Was there any info on noise or thermals? I watched a couple of reviews but nothing mentioned... and I cannot watch 12 hours of tech Jebus sending me into a coma...
A 6800 XT should be a nice upgrade from the GPU in your sig.![]()
True true.Nah, ill get another year out of it. Ive been thinking about whacking in another 128mb ram, might be overkill though.
). Otherwise pairing that with a current gen 3900 or 3950 would have done me this gen and then do a full upgrade next GPU drop with a 5000 series CPU.If you look at performance comparisons in recent games, it swings AMDs way. If you look at a lot of older titles, it swings the other way. Be interesting to see what happens going forward.Results this time round vary massively between reviewers depending on the games they use and their test bench. It's quite hard to actually gauge where performance is as my take away was below 4K AMD is comfortably ahead and at 4K nVidia wins overall by a fairly slim margin. Add to that the fact that nVidia seemingly never intended for cards to hit their MSRP makes the AMD offering pretty compelling.
I'll still be waiting until early next year before considering an upgrade though.
Noise seemed fine on the cards reviewed.
Since I have just switched to a 3440x1440 display from 4k the 6800xt would have been ideal.
Would it though? I'm guessing you upgrade fairly frequently by the sounds of things, but they're about even at that resolution, and DLSS would help keep the frames up in newer titles that come out... or at least that's how I'm looking at it ... but maybe we see things differently based on how long we expect to be using bits.
The games I mostly want to play or play seem to show much better performance for the AMD gpu. Valhalla and Grid 5 are on top of my list at moment. I also play R6S a lot still although kinda irrelevant bearing the FPS both achieve. Not to mention Gofall and Death Stranding which am also keen to play. With that too AMD working on their equivalent to DLSS will be interesting because even if that is a year out then it would do similar with keeping up in frames with newer titles as well.All AMD need to do is get stock out faster than Nvidia over the next month or so.
That doesn't appear to be what's going on to me. OcUK are saying that they won't be getting any more stock of the reference design. Not that there's a supply problem or that it'll be a while before they get more stock. Just that there plain won't be any more. It seems like AMD never planned to produce more than a few thousand of these things and everything's gone into the partner cards instead. Although quite why they'd decide to press ahead with the launch yesterday anyway after seeing the reaction to Ampere and its shortages is an entirely different mystery.They won't though, will they. It's painfully obvious that they were not at all prepared for this release, and probably won't be for many, many months.
