Hi
Having some strange issues with my new build. Sometimes when I boot up my pc and log in the mouse drag and scroll option using the middle mouse click button wont work. This is accompanied with the volume/media overlay getting stuck on screen if i press a media key, Video stuttering (won't play just stuttering at the start) if i try to play any video file saved on my pc. this only happens using the default film and tv app and plays fine using any other media player. And I can't right click on apps and files for options.
I have no problem using the pc while this is happening and can still play games, watch movies ands other things.
A restart always fixes it and everything goes back to working as it should.
I have tried a clean install of windows but it did not fix it, a different bios version but that did not solve the issue and i have tried a different mouse.
I did unplug the mouse once and put it in the front usb port on my case and it fixed it but have done this again a few times with no luck. This led me to think it was a mouse driver issue but i have uninstalled/reinstalled drivers, updated firmware. uninstalled software, tried another mouse but still have the problem.
Tank you
(Edit: Seems that when i unplugged my usb microphone from the back panel and replugged my mouse fixes the issue.) I wonder what is causing this, could it be psu related?
Also the pc sometimes won't wake from sleep. The fans will spin but I have to restart the pc. This does not happen every time and I don't know if it's related.
The psu is a 6 year old be quiet so I might replace that to see if it solves it.
Tank you
