I used Decibel X on the iPhone.What app you guys using? Is it on iPhone?
)Mine is 100% coil whine, easy test for this is that the sound pitch or tone changes when looking around in the game as the load changes, looking at the sky/ground/highly populated area etc.
Fan spins freely - No issues there.And if it's fan related, you'll hear some noise by making the fan move when the console is powered off (ruling out coil whine/disk drive).
If mine has the fan whine, I can't hear it over the coil whine!
It's a little annoying, especially as the series X is completely silent from reports - there's a lot of reports of coil whine so hopefully Sony will acknowledge the issue.
Putting the headphones/headset on solves the issue though! Sort of...![]()
It's not completely silent at all. People don't seem to know what silent means.
Source: Had one for 3 hours![]()
Compared to the PS5, the Series X is for all intents and purposes silent. Both are much better than previous consoles but there is no comparison at the end of the day.
No, you can say it's quieter, its objectively false/wrong to say it's silent. My PS5 is a bit louder than the series X but the only fair comparison would be to play the same game on both, didn't have any next gen games to try on the X. Neither consoles are loud to me though.
"for all intents and purposes"... i'm not saying it's silent.
At a distance of about 8 feet it's inaudible. The PS5 isn't.
lol, give up on the "no next gen games on the Xbox" either, what next gen games are you referring to for PS5?
Both of your points there are strangely fanboyish.
If you have to mute your TV to hear the console then it’s quiet, you could hear the PS4 pro easily over TV audio."for all intents and purposes"... i'm not saying it's silent.
Every year I unblock you for a bit to see if you've grown up, you've failed for the last 5 so back on it you go, permanently this time. You are certainly in no position to call anyone on this forum fanboyish either.
