Caporegime
- 30 Jul 2013
Got enough RAM in that?
Sometimes I think I should've got 384gb for 8k video tbh but the 3090 helps.Got enough RAM in that?
Have you got more than one screen attached?
Nvidia cards always used to go at full clocks if two or more screens are attached. Not sure if it applies to the 3000 series though.
I do yep but for it to be untouchable on the backplate but gpu temp showing 48~ i find weird.
I have an Intel Xeon W-3175X, 192gb 3200 cl14, dominus extreme, 2x 4tb 860 Evo, 2x 12tb WD gold, 4x 4tb mp510, rtx 3090 founders(getting second at some point) and LG OLED 48CX.
thanks, currently running with case side off till new case arrives with a bit more airflow/roomNormal, it gets very toasty, I wouldn't be worried.
Overkill isn't a term I use.Quite the setup...bit overkill for me, as I have a wife, three kids and a mortgage........Nice though never the less! That is a lot of RAM to refresh per clock cycle....
For what it's worth, I just got shipment notification for my strix 3090 block from EKWB. Finally able to put it under liquid hopefully this weekend! Looking forward to getting some decent overclocks on the thing to set some benchmarks
Arrived yesterday ASUS TUF OC 3090..
Made a post but if anyone has the same card, have you experienced a super hot backplate on it? Hot enough you can't touch even though its just browing web/emails?
Pulled the trigger today on the Inno3D iChill Frostbite 3090! Was hoping it would have been delivered tomorrow as OcUK had 5 in stock when ordered - still at order received status! Biggest purchase by a country mile ever in my 22 years of PC building/gaming! What's everyone's thoughts on the 3090? apart from the fact its ruddy expensive!
Thoughts? Biggest purchase in every sense of the word. Its bloody massive its about the size of a brick and about as heavy it takes up 3 slots and I actually have three thumbscrews securing it tightly normally I only bother with one on two slot cards, but the thought of that thing breaking loose it would probably knock a hole in the bottom of the case. I'm joking. But my lord its heavy. I wouldn't want it any longer either it fits but any bigger I'm going to need a new case or remove some cages. It is solidly built though and oozes quality (FE). Its also remarkably quiet in use though it consumes vast amounts of power (350W, 400W if you OC it. Tried that but it only equalled a few more fps and I'm not sure its worth it)
