3700 calories?? lol Me thinks your calorie counter is broken!!![]()
If it includes natural daily burn, and he's played for hours on end, then I reckon it's doable.
What are you running it on?
Unless.....is there an X-rated version of Beat Saber?
2 minutes of exercise will hardly lose 3700 calories![]()
Could using a power plug to connect your pc to a router help?Anyone have an idea of the minimum throughput/bandwidth needed on WiFi to run Virtual Desktop? I know 5GHz is a must if using WiFi, not sure I can easily get a cable up to the main rig but the WiFi dongle I use for it is ancient.
anyone got or tried the AMVR in ear headphones ?
https://www.amazon.co.uk/AMVR-Isola...cementKeywords=oculus+quest+headphones&sr=8-4
tempted at £15
Never used them before but worth a consideration if I can't beef up the current WiFi or run a cable. I still want to try the latter and it's an easy run, my only worry is it being a trip hazard as it has to run under and along our bedroom door. A flat Ethernet cable and something to keep it down/flat might do the trick.Could using a power plug to connect your pc to a router help?
tempted at £15
I’m using the 3000 TP-links in a new build house and even then the lag is still noticeable compared to Ethernet to router gigabit port. TP-link software showing connection anything from 170mbps to 350mbps I haven't tried to VD it yet but I’m 90% expecting it to be a stuttering mess without going direct with Ethernet.Could using a power plug to connect your pc to a router help?
Than the quest 2 tubes? absolutely!.For 15 quid are they going to be any better than built in.....![]()
the thing i like about the tubes is the naturality of the sound... because they are off ear its a lot less like wearing earphones but actual sound quality, compared to the CV1 i am coming from is night and day difference. am hoping the G2 will offer a best of both
