Sorry if this has been asked - but thinking of picking up one of these and curious how big the file size is for the Quest version of Alyx?
Alyx is on Steam. You don't download it into your Quest, you need to connect your Quest to your PC to play it. Either Wirelessly using Virtual desktop/ALVR or using a USB 3 cable(Oculus Link)
i would agree with acceptable....... I also agree about the noise leakage, which is not usually an issue for me but the boss did tell me she could hear everything.Quest 2 audio is very good - better than Quest 1. Doesn't compare with the Index or G2 but it's a perfectly acceptable sound solution. The biggest issue is sound leakage, so I have to use headphones when my wife is around otherwise she starts compaining.
Oh ok, now I'm confused...so do I need anything else to play it wirelessly?
Never used them before but worth a consideration if I can't beef up the current WiFi or run a cable. I still want to try the latter and it's an easy run, my only worry is it being a trip hazard as it has to run under and along our bedroom door. A flat Ethernet cable and something to keep it down/flat might do the trick.
For 15 quid are they going to be any better than built in.....![]()
The Quest/Quest 2 has it's own games and apps. If you check out the Oculus site and go to the store page you will see the list of games/apps it has available. These are all things that run natively on the Quest 2. You don't need a PC to use the Quest this way.
However, you can connect your Quest to your PC if you want to play PC VR games. PC VR games include games that are available for the Rift/Rift S on the Oculus Store and games on Steam. Half Life Alyx is a game that's only available on Steam.
Two ways to connect to your PC.
Wired:
You buy a USB 3 cable compatible with the Quest (Anker is the one usually recommended) or you pay extra for the fibre optic cable from Oculus. You install the Oculus software on your PC. And when you connect the cable to your Quest there is an option to use Oculus link. You will be able to start your PCVR games from there.
Wireless:
Wireless is a bit more complicated. You will need a Router capable of 5GHz. It's preferable to have the Router in the same room as the Quest to get the best latency. You will need to buy Virtual Desktop from the Oculus Quest store. Then you download Sidequest and connect your PC to the Quest using a usb cable. From Sidequest, you install the Virtual desktop Patch. Then all you need to do is run Virtual desktop from your Quest, it connects wirelessly to your PC and you can play any game that you have installed on either Steam or Oculus.
It sounds a lot more complicated than it actually is.
but audio is very good? i cant agree with that.
i like the idea of off ear sound tho even if it is more irritating for other people
I use in ear headphones at the moment (Senheisers), i don't like the leakage, and i prefer to be more immersed
25 mins on beat saber so far
222 calories burnt
ill be doing more later
oh and when i switched my Quest 2 on, it said "Bluetooth has stopped working"
i have no BT or Wi-fi now
but controllers are working fine
excellent, how long did it take?
so where the hell is this Fitness Tracking now we got V23 ?
where is it![]()
I'm sure I've looked there before
maybe its there now, i will check , ty
