Don
- 20 Oct 2002
- Oxfordshire / Bucks
Can you you use a USB A to C adaptor on the official Link cable?
Non-official cable (Quest 2)
YES
i do
With the new link functionality it blows the Rift S away, but you'll need a good GPU to be able to drive it effectively at the higher resolution.
For native games, the graphics quality is downgraded, but wireless makes a huge, huge difference.
I bought this primarily to play via link on cable or virtual desktop and Iv been so blown away by the stand alone games quality and the zero faff that Iv only put in about 30% of my time in Rift connected mode. Yes the quality of graphics is insane at 2k per eye but the stand alone nature of some games has to be admired. Good thing is there is something for everyone with this set.
This is the one I'm using, despite the random brand name it's all good, it comes up as USB3 with speed of around 2.3Gbps, I've used it several times over the last few days without issues.
https://www.amazon.co.uk/gp/aw/d/B088BTHDFJ/
topgun, any of the games in PCVR that are free ?
if you got any that your having problems with, i'll try it on mine
So far the Q2 is a huge step up visually from my CV1, the only issue is lack of battery life.
Cheers. I've just cut 3m of twine to test the rangeIt seems enough. I take it that it is fine for you?
I was not experiencing any issues I'm aware of but I was only getting 1.1GBps using my front USB ports. Just switched to a rear 3.1 port and now get 2.3GBps but have around a meter less cable due to the depth of the PC! I'll have to test Dirt Rally 2 and see if it looks any clearer on the faster sections.
Edit:
No, makes no difference at all. I suspect the 1.1 speed is enough anyway.
I've been using these 2 cables without issues, before and with the new update. Get a good 2.8GBps with this combo.
https://www.amazon.co.uk/gp/product/B01MZIPYPY/
https://www.amazon.co.uk/gp/product/B073J92722/
It is literally the worst but of launching software bar none on the PC. It’s like looking at software from the 2000’s.Anyone else have issues with SteamVR?
There are times when I don't want it interfering. Yet it loads up anyway. Even if I've shut Steam. Is this a Virtual Desktop thing? Or is the software just a bit of a ****?
Interesting. Can you confirm what render resolution, bit rate and Hz you are running at? It’s crazy that there are so many people having a wide variety of experiences. The problem is obviously hardware related but what part?
How do you mean mate?
