New CPU for around £400
Pick up a 3900X or a 10700K if you want something now or go for a ryzen 5800X if you don't mind waiting till around Easter next year.
For 400 total buy b550 motherboard(~110) Ryzen 3600(~180) + 16 gb of 3200Mhz RAM(~90). Should be around your budget if you chose well
i do agree my £65 3600mhz Micron Rev. E dose like to play
Since getting on a newer Bios on x570 this micron ram is absolute beast for the money will do 3800 cl14, sure I can do 4000 but never bothered uncoupling IF, but will test soon ready for 5000 series. Plus can get them quite tight too across the board, only thing they don't like is low tRCDRD and tRFC when comparing them to B-die. I can run 3800cl16 now at same voltage I used to run at 3533cl16 (max on older bios for me) and ive tested the crap out of them too, no reddit OC's.
