Google is your friend, they have the answer![]()
I did and still non the wiser. lol
It doesn't matter. I feel a thread diversion on its way.
Hey guys, do you think this is a good score compared to the average graphic scores? Powercolor 6800xt, I didn't oc just raised fans and power limit to the max: https://ibb.co/xqg9P1c graphic score is: 18246
Definitely max power slider. Then +100 mhz on memory. The real fine tuning if you're interested will be in undervolting first of all, and combined with some core freq changes. Simpler is to just test out undervolting until the card crashes and leave stock freq alone. If you can drop 100mv from stock and it's stable, then call it a day and be happy. Otherwise more elaborate and rigorous OCing would at best net you 3-5% extra over such simple OCs.Looking to have a play with an OC for my 6800XT.
What settings would you lot recommended?
Plus is an OC worth it on this card? For an extra 100mhz etc..
Arsenal Gaming branded motherboard.Gunners?
Yeah it looks to be a recognised bug atm, hopefully next driver will sort it.
This is good advice. Just remember to check in game to see if increasing the memory clock does indeed increase performance.Definitely max power slider. Then +100 mhz on memory. The real fine tuning if you're interested will be in undervolting first of all, and combined with some core freq changes. Simpler is to just test out undervolting until the card crashes and leave stock freq alone. If you can drop 100mv from stock and it's stable, then call it a day and be happy. Otherwise more elaborate and rigorous OCing would at best net you 3-5% extra over such simple OCs.
https://www.igorslab.de/en/amds-rad...ck-thanks-morepowertool-andboardpartner-bios/
https://www.igorslab.de/en/amd-rx-6...ting-von-ueber-240-watt-bis-unter-180-watt-2/
Yes, I have the CRG90, is that the same display as yours?Anyone using a 6800 with a Samsung 49" Ultrawide?
I have this annoying issue. When I first boot the PC, once Win10 is loaded, the screen goes blank.
I then have to cycle the screen on and off a few times and it eventually stays on.
I booted the PC into the BIOS and left it for a while and the screeen didn't go blank so it's not the monitor.
I have filed a ticket for a bug that causes a black screen on resume from sleep, Hibernate works fine thankfully. I do not see any other type of black screen though.
Try a DDU in safe mode then install the new 20.11.3 driver.
Sapphire Reference 6800 from OCUK had it since 1st of December
here are some scores with it and 5900X
https://www.3dmark.com/fs/24216880
https://www.3dmark.com/fs/24217652
https://www.3dmark.com/fs/24217650
https://www.3dmark.com/spy/15901062
https://www.3dmark.com/spy/15901078
https://www.3dmark.com/sd/6139899
https://www.3dmark.com/wl/31700
