Just do this, works 100%.Thick bleach with some rolled up tissue paper. The tissue prolongs the contact time on the mould and speeds up the removal.
My understanding is bleach hides the mould by killing (and "bleaching" the colour away) the surface stuff, but doesn't kill all of it.Bleach.
It'll always return on the colder sufaces of a house, if there is moisture in the air. What you don't want to do is paint over it, without killing it first.My understanding is bleach hides the mould by killing (and "bleaching" the colour away) the surface stuff, but doesn't kill all of it.
Do you find it returns in the same places?
You have to leave it to soak deap down to kill as much as it can penetrate , a lot of people just spray then wipe and think it will go away but not true.My understanding is bleach hides the mould by killing (and "bleaching" the colour away) the surface stuff, but doesn't kill all of it.
Just be sure to use bleach and not toilet gelI'm currently giving the bleach + tissue method a go as I type. Started a couple of hours ago, should have taken a photo before, but it should be clear if it's done anything as I only did have of one section.....just in case.
This but wear gloves.^this is the correct answer
