I had some issues with fan control until I switched to afterburner 4.6.3 beta 3 which seemed to fix this.Quick one... Ventus 3080 playing Watchdogs. Fan drops to 0, gpu temp up to 75c... Afterburner fan curve makes no difference? Only happens in this game so confused?
ok cheers will give it a goI had some issues with fan control until I switched to afterburner 4.6.3 beta 3 which seemed to fix this.
The download link is near the bottom of this page.
https://forums.guru3d.com/threads/rtss-6-7-0-beta-1.412822/page-131
congrats!Add me to the club
Add me to the club
Did you do stock tests before and after to see how much extra boost you get by going water?I put the 3080 FE under water yesterday, doing some tests.
Here's time spy with +140 core and +100 memory, it says GPU clock 2100mhz with avg 2017mhz, without overvolt, how's this result?
https://www.3dmark.com/3dm/54461574?
This is at +160 core and +120 memory no overvolt
https://www.3dmark.com/3dm/54462520?
As for 3DMark, you need top get us valid scores so we can compare properly.
Don't know, maybe put nvidia settings to default.Not sure why it says invalid though? How can I make them validated?
Yes It wouldn't boost over 2ghz on air, will do more tests in the weekend
