HP microsever gen 7 disk size
18 May 2004
Lincoln, Uk
Looking to get a bigger drive to put in the microsever, unfortuntaly the infortmation online as to whats compatianle is a bit hit and mis, at first it appears only quite small drives are suported, then you get a comment that it actually supports bigger than that, and thats only what it was tested with at the time of the info at the time of being released.
So I thought I'd put it out here, because I'm sure their are some Micorserver owners here (Think its the N54L I have) I'm sure someone would have tried larger drives in one
15 Oct 2005
Earth, for now
Using a 10TB one in mine, amongst others, and it is fine.
I sometimes think about "upgrading" but it still does what it is needed for, and cheap to run the N54L.
