Don
- 20 Oct 2002
- In a house
Weak starter motor, or perhaps a low battery?
What do the spark plugs look like? If it is starting cold without choke it points to a mixture issue. Do the plugs look like it’s running rich?
Are you sure the starter is (always) actually turning the engine over? It sounds silly but remove the clutch cover plug thingy in the middle of the clutch housing (if it has one) and see if the engine is actually rotating under the starter. Be careful of oil leakage.Update...
Bump starts instantly.
Is pretty much fine except when cold starting.
Not sure if that means anything to anyone.
I have no idea. Sounds OK... But I'm confused... If I take the clutch cover off yeah they'll be oil everywhere and clutch wouldn't work... The cable that goes into the clutch cover is just the clutch cable I think.Are you sure the starter is (always) actually turning the engine over? It sounds silly but remove the clutch cover plug thingy in the middle of the clutch housing (if it has one) and see if the engine is actually rotating under the starter. Be careful of oil leakage.
There's often a screw in plug right in the middle of the whole clutch cover housing, it's removable to allow easy access to the crank bolt so the engine can be rotated manually.I have no idea. Sounds OK... But I'm confused... If I take the clutch cover off yeah they'll be oil everywhere and clutch wouldn't work... The cable that goes into the clutch cover is just the clutch cable I think.
Well this is the cb600 (2000)... Can't see one on the clutch case here.There's often a screw in plug right in the middle of the whole clutch cover housing, it's removable to allow easy access to the crank bolt so the engine can be rotated manually.
It may be on the other side of the bike on the crankcase cover, I don't know cb600s well?
like this:
If it’s running rich you should be able to spot it by now.Having said that they've had a few miles now, maybe around 150 since last checked, is that long enough to diagnose anything?
