- 2 Aug 2004
- Glasgow, Scotland
Yeah my palit has not shipped yet either .
I've got a GTX 1080 and will hopefully be collecting an RTX 3060ti FE tomorrow evening.
If you want I can do a benchmark in the one game I've got installed (AC: Valhalla) or free software of your choosing?
Took receipt of my MSI Gaming X Trio and have run TimeSpy with a top result of 11035.
GPU - 12333
CPU - 6913 (Ryzen 5 3600)
Happy with that compared to the 5700XT
I'm sure if I pushed the card more and the CPU too that I could get it higher but I'm very happy with where it is in terms of performance & thermals (CPU & GPU never went above 70°C)
GPU - 12333
It's worth thinking about overclocking, or at least increasing the power limit to max. Below is the score with my balanced overclock on an FE (and with a 1600AF @ 3.95Ghz):
Overall: 11223
Graphics: 13223
CPU: 6269
http://www.3dmark.com/spy/16007932
GPU and CPU both relatively cool (sub 65 degrees) on that run too.
This is what I've set it too for now:
I'm on a 1600AF as well, be interesting to compare mine to yours once I've done some tweaking.
I will say one thing though, the FE runs 20oC cooler than my RX580 did, although my 1600AF is stock and you're getting about 500 more than me on the CPU front.
So thats roughly 20% over a 5700xt. an impressive little card!
Whack +150 on the core it handles it easy (mine does) Timespy went up to 12437 from 11000 something.
I'd be very interested to see what your results are once you have a play around with the clocks. This card is such a great upgrade (I came from an RX570) and I'm really pleased with its overall performance.
What FPS did you get in Warzone please? Was it 1440p ultra with RT on?I've not really done anything with mine yet, I literally uninstalled the AMD drivers, took the card out, put the new card in, drivers, 3dMark, half an hour of Warzone with all the settings maxed out and that was it, I was impressed with the temps as its 20oC cooler than my 580 was, it is bloody heavy by comparison.
Earlier in the thread I commented that my FPS was a bit low as YouTube videos showed 130ish stock. I think I’m probably bottlenecked by my CPU and you might be able to help prove it![]()
I set my power limit to 110 on the FE, and have +160 core and +1400 memory. Those settings gave me the best benchmark results whilst being stable in everything I've tried. Pushing the core even a little further caused instability and moving the memory up gave me artifacts and lower scores.
I also set the fan to 55% at 40 ti 80 degrees and it stays very cool.
