OcUK RX6900XT review thread
So where are these guys now then? When the RX6900XT was first announced saying?!?!?!
"WHOOOAAA!!!! THE RX6900XT IS AN RTX3090 KILLLER AND CHEAPER!!!!!! NVIDIA IS FINISHED!!!!!!FINNNNNIIISSSHHHEDDD!!!!!!"
They seem quiet now?
Where are the people who said amd would only match or just beat the 3070.
So on par with the 3090 then, except that beats it on even poorer value per unit cost according to HU's stats.
The 3090 is 50% more expensive bit has much better 4k and RT performance.
The same can be said about the 3090 over the 3080 but people are still snapping that up as if it's cheap candy.
That's because the 3090 is ironically more available and people are getting patient and in some cases desperate enough to override common sense. Things become a lot easier to justify in your head that way.
From the benchies i've seen the 6900xt is more or less on par or slightly faster than a 3080 or 6800xt! I'm glad i didn't hold out for one...
I wondeer how reviews choose what games to test? I noticed J2C used mostly older titles when reviewing the RX6900XT whereas Coreteks used mostly newer titles. The choice of games does materially effect the results and conclusions it seems.
AMD's VR drivers are broken. Not working with HP headsets.
so basically
Vr: the broken on amd
Dlss: non existent on amd
Ray tracing: bad performance on amd
Rendering: bad performance on amd
Ray Traced rendering: broken on amd and bad performance
These things all add up
It would be interesting to see how the framerate percentage difference between red and green changes as the age of the game changes.
so basically
yeah but SAM and Rage . though.
+ broken crappy website that was programmed by a monkey.
+ plenty of stock
win
Recovering mindshare, one customer at the time.:D
Here's a top tip for you AMD.:cool:
Make a decent website for a start if you want to sell items.
Or pass it to a actual retailer that can do the job, because you bloody well cant.
so basically
Does Jensen have a pic of you 2 in suspenders or something? Your constant shilling is getting really old.
To be fair, neither can Nvidia on that front. They also had/have all sorts of problems on their website with this launch.
This is what the 3080 competitor should have been imho, its not a bad card and hats off to AMD for pulling out this kind of performance it just doesn't make sense as a product. Not to me at least....
Definitely looking forward to seeing what RDNA 3 brings.
hence why the passed it onto an actual retailer. And guess what? It just works.
oh wait....
get back to your echo chamber son.
