3060Ti
8 Dec 2020
Took mine for a little spin.
Palit 3060ti dual
Stock was boosting from 1700ish-1925mhz (just and back down). Stock fan profile seemed quiet enough and it levelled out at 73°C after a few loops of Heaven.
1080p ultra, tesselation extreme, AA 8X
I think it was 190 fps, 430ish max, 26 min, 4800ish overall score.
Edit: apparently I'm either too stupid or my post count is too low to add images
Sorted for you from your friendly neighborhood mod :D
Caporegime
18 Oct 2002
Very nice card this (Giga 3060Ti OC Pro), whacked it in earlier and it's silent with good performance! Tweaked vs tweaked against a 3080 I'd say the 80 was roughly 40% faster.
Caporegime
18 Oct 2002
Just got my Gigabyte Gaming OC. There's meant to be a silent/oc bios switch on the card? I can't find it.
This image may help to locate it;
8 Dec 2020
I'll need to mess with the fan curve a bit to see what I'm happy with noise wise for daily. 100% is definitely noisy but not actually bad on this card.
Max power, temp, fan and +150 on the core and it's doing really well! Boosting to 2085Mhz and hovering around 60°C. Nice little bump in Heaven score too.
5068 now.
8 Nov 2020
5068 now.
Rather than spending time making a fan curve you could try setting max temp on the GPU to 70 - 75c, perfectly safe and the fans shouldn't ramp up as much.
10 Feb 2009
Leicester
Is anyone else having issues with the lighting on the zotac 3060ti when opening the firestorm software the spectra (lighting menu) is grayed out Apart from that the card is great
Non OC version does not have light up LED on the side.
Also mine is doing this when fans are between 37% and 47% , not sure if its normal??
22 Feb 2019
Ost Angelnen
yeah I’m so annoyed! Looks like my delivery driver punched a hole through it. It went through the polystyrene too.
https://ibb.co/jfm8YPw
https://ibb.co/r3rWn4n
haven’t tested the card yet. Waiting to see what OC want me to do.
They really should make drivers financially responsible for their cargo, with any damage coming directly out of their wages. I guarantee they would be far more careful! :p
9 Nov 2020
The zotac gaming logo is supposed to light up I’ve had to same problem too.I called the zotac customer service and they said other people are having the problem to and that it may be an issue with the firestorm software
