God that gets me moist, I loved tinkering with my v56Received my 6800, wow these cards like a good tinker. Reminds me very much of the vega56 i had.
Yeah it was great, I had mine out performing my Vega56. Great card!
The Vega cards don't deserve the hate they get
What tinkering are you doing?
Loved my vega 56. Bought 2nd. Still regret seeling it, the faulty 5700XT that replaced it wasn't worth he hassle.
Yeah for sure, my v56 is now out performing my friends 1070ti
Not on Roll of Honour, have I done something wrong?
Not on Roll of Honour, have I done something wrong?![]()
Full system specs?Hi guys, I'm experiencing weird crashes while playing with the 6800xt: the screen would hard freeze and I have to manual reboot. I've got a slight oc on the gpu memories +100, and nothing on the gpu clock. Usually when the system lock like this and doesn't go back to windows, could actually be a gpu issue or something else? (ram or cpu oc)
edit: also I had a freeze like this when I was installing the new drivers for Cyberpunk (first time that happens in windows)
I'm with a 9900k 5.0ghz, 16gb corsair 3600 cl16 (oc), aorus z390 pro. I'm quite sure once happened even at stock vram settings, but I'll need to dig deeper onto this.Full system specs?
Does it happen with the GPU memory at stock?
PSU? Using two cables?I'm with a 9900k 5.0ghz, 16gb corsair 3600 cl16 (oc), aorus z390 pro. I'm quite sure once happened even at stock vram settings, but I'll need to dig deeper onto this.
I'm making tests to see once everything is at stock, but the Psu is a corsair rm750. I have one cable splitted in two 6+2 pin, is there any issues with Amd cards and Psu cabling? I've read that thing somewhere and now I'm thinking about it.PSU? Using two cables?
Does it happen with everything, CPU, Memory and GPU at stock?
The thing is I ran realbench when I did my cpu oc, and I passed the test. Now for the RAM maybe is not the best test and I should try memtest? Anyway I've already reverted everything and let'see, thank you guysI would revert everything to stock, GPU, CPU, memory and run realbench then if that passes, re-run realbench with the RAM OC first and go from there.
The thing is I ran realbench when I did my cpu oc, and I passed the test. Now for the RAM maybe is not the best test and I should try memtest? Anyway I've already reverted everything and let'see, thank you guys![]()
Memtest is good, do it anyway as standard but the problem is when your CPU becomes stressed under load it can knock over your ram OC and that’s where realbench is good.
Try increasing your sys ram voltage slightly to 1.36/1.37. Had similar on my 5700XT and it solved it.
